Best way to reset multiple switches at once ??????
rtr679
Hello
I am in charge of networking cisco lab for students to learn on Catalyst 2960s & have been trying to research how to factory reset multiple switches at once, in case the students dont reset it properly.
I have come across tcl/eem/expect/smart install/remote shell/plink/octal cabling but still struggling to find a way to do this as I have always struggled with scripting regardless of how many examples/tutorials I come across.
If anyone has any ideas or good documentation any help would be much appropriated the biggest problem I see is that some of the auto methods need you to telnet/ssh into the switch which isnt practical & from my limited understanding to try & hook up many switches to a single switch wont work as the switches wont be on trunk port mode to be able to talk to a "master" switch?????
PS: Also looking for a way to automate a password reset for the switch for when the student uses a different password & forgets to factory reset it if that is even possible????
marce1000
 - Factory reset is intended to use sparse and usually require access to the device such as for instance the need to press a reset button for a number of seconds. You can not acquire this with scripting only.
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
marce1000
 M.
Thank you for the reply :)
