BFD and trunks
glsparks
So i have a number of 3850s running ipservicesk9 with multiple vrfs.
The switch has two SVI's that are trunked to another device e.g VLAN 10,20 with each VLAN being a layer 3 interface within a separate vrf.
vlan 10
vrf forwarding RED
ip add x.x.x.x
e.g int g1/0/24 switchport trunk 10,20
I am experiencing BFD flapping which is tearing down my BGP sessions for both BGP peers.
Continually seeing $BFDFSM-6-BFD_SESS_DOWN in the logs
Have confirmed no physical issues with the cabling the connection is 1000-BaseT
Interfaces on both devices are not showing any errors, drops or high utilisation.
A BFD template has been applied to both VLAN interfaces. No BFD config applied to the physical interfaces.
int vlan 10,20
bfd-template single-hop BFD-TEMPLATE
interval min-tx 500 min-rx 500 multiplier 3
Any ideas what this could be? I am suspecting a bug in the code 16.12. Or is the BFD configuration to blame?
5 Replies 5
Reza Sharifi
Could you try adding the BFD to the physical interface instead of the VLAN and testing again?
BFD is more for tearing down the physical interface than a logical interface (VLAN).
why two vlan ? why not only one, the one that use as bgp update source and neighbor
MHM
Two VLANs as they are each in different VRFs.
Can I see bgp config
MHM
Looks like the issue is hardware related. The far end is a Palo and it is reporting interface errors.
