BFD over vPC peer keepalive link
booshanm
Shall we configure BFD over vPC peer keepalive link?
I do not find documents mentioning BFD & vPC KA together. But there are simply no BFD commands available under mgmt0. This is sufficient as an indication it is not supported :-)
Sergiu
Sergiu.Daniluk
Short answer: Nope :-)
Long answer: BFD is not supported on mgmt0 interface, which is usually interface used for vPC peer-keepalive. Even if is not mgmt0 interface used for vPC KA, there is no advantage of having BFD enabled for this. Anyway, KA by itself going down will not impact in any way the vPC domain. You need peer-link as well to go down.
Sergiu
Any useful link,which represent this?
Sergiu
Thanks,msdaniluk.
