BGP best route decision question
mahesh18
Level 6
Level 6
Hi All,
I have two Routers directly connected by EBGP.
R4 and R1  have two conenctions to each other.
1  by serial interface other by loopback.
R1 is advertising the networks to R4.
R4#sh ip bgp
BGP table version is 6, local router ID is 10.4.4.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
   Network          Next Hop            Metric LocPrf Weight Path
*> 50.1.1.0/24      1.1.1.1                  0             0 5500 i
*                   10.1.45.1                0             0 5500 i
*> 200.1.1.0        1.1.1.1                  0             0 5500 ?
*                   10.1.45.1                0             0 5500 ?
*> 200.1.2.0        1.1.1.1                  0             0 5500 ?
*> 200.1.3.0        1.1.1.1                  0             0 5500 ?
*> 200.1.4.0        1.1.1.1                  0             0 5500 ?
Here we can see that best path is 1.1.1.1  and thats in routing table also.
i know BGP chooses best route based on some 14 attributes.
Here AS distance,metric,Weight and local preference is same.
Can someone please tell me how R4 choosed 1.1.1.1 as best route?
Mahesh
Roman Rodichev
Level 7
Level 7
Roman Rodichev
Level 7
Level 7
13. Prefer the path that comes from the lowest neighbor address.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
Hi Roman,
Many thanks for correct reply and info on  useful link.
MAhesh
