BGP pinging layer 3 switch
sisqo2006
Hi guys,
I have been trying to familiarise myself with BGP and have come across an issue that I would like some assistance with. My set up is as follows:
I have 2 routers and 2 switches (L3)
R1 connects to R2 and uses BGP               R1 G0/0> 10.10.10.1                       R2 G0/0> 10.10.10.2
R1 connects to SW1 and uses EIGRP        R1 G0/1 11.11.11.1                         SW Fa0/1> 11.11.11.2
R2 connects to SW2 and uses EIGRP        R1 G0/1 12.12.12.1                         SW Fa0/1> 12.12.12.2
The issue that I have is that if I try to ping 11.11.11.2 from R2 it fails (the same applies to R1 if I try ping 12.12.12.2)
Hopefully the configs will explain a bit more, can anyone give me some info on this please?
R1:
Router#sh run
Building configuration...
Current configuration : 791 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
license udi pid CISCO1941/K9 sn FTX152422EV
spanning-tree mode pvst
interface GigabitEthernet0/0
 ip address 10.10.10.1 255.255.255.252
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 11.11.11.1 255.255.255.252
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 redistribute bgp 66
 network 11.11.11.0 0.0.0.3
 auto-summary
router bgp 66
 bgp log-neighbor-changes
 no synchronization
 neighbor 10.10.10.2 remote-as 77
 network 11.11.11.0 mask 255.255.255.252
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
R2:
Router#sh run
version 15.1
hostname Router
license udi pid CISCO1941/K9 sn FTX15243T7E
 ip address 10.10.10.2 255.255.255.252
 duplex auto
 speed auto
 ip address 12.12.12.1 255.255.255.252
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 redistribute bgp 77
 network 12.12.12.0 0.0.0.3
 auto-summary
router bgp 77
 no synchronization
 neighbor 10.10.10.1 remote-as 66
 network 12.12.12.0 mask 255.255.255.252
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
SW1:
Switch#sh run
Current configuration : 1233 bytes
version 12.2
hostname Switch
ip routing
interface FastEthernet0/1
 no switchport
 ip address 11.11.11.2 255.255.255.252
 duplex auto
 speed auto
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/2
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
SW2:
Switch>en
Switch#sh run
version 12.2
hostname Switch
ip routing
 no switchport
 ip address 12.12.12.2 255.255.255.252
 duplex auto
 speed auto
interface Vlan1
 no ip address
 shutdown
router eigrp 1
 auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
 login
end
5 Replies 5
David_Che
SW1 and SW2 did no have route to 10.10.10.x/252. please advertise them into EIGRP.
How do I provide this route. I thought if i used the redistribute bgp it would work. Any examples please?
You need to specify a metric when you redistribute into EIGRP.
So you can either specify it with the redistribute command or you can specific a default metric under your EIGRP process.
Jon
Sorry I forgot to mention that I also applied a metric to the command.Still no success.
Can you post -
1) "sh ip bgp summary" from both routers
2) "sh ip route" from all devices
Jon
