BGP Routing Problem using Route-map
Sabby0115
Hello Everyone
I have an issue with BGP routing lab. I want to ping loopback 1 from R1 to loop 6 in R6 & vice versa , but i don’t want any other router into routing table except BGP peers & loopback1,6&7. All other config is working fine is working well. but in R2 under bgp process when I do redistribute ospf 1 route-map xyz it won’t pass the ping to the destination. I am putting my config file so you guys can find my error.
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface Loopback1
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 172.30.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
router ospf 1
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 172.30.1.1 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
end
R2
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip address 172.30.3.2 255.255.255.252
duplex auto
speed auto
interface Serial0/0
ip address 62.150.1.1 255.255.255.252
clock rate 2000000
ip address 172.30.1.2 255.255.255.252
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router ospf 1
router-id 2.2.2.2
redistribute bgp 5500
network 172.30.1.2 0.0.0.0 area 0
default-information originate always
router bgp 5500
no synchronization
bgp log-neighbor-changes
redistribute ospf 1 route-map OSPF_FILTER
neighbor 62.150.1.2 remote-as 777
neighbor 172.30.3.1 remote-as 5500
no auto-summary
no ip http server
access-list 1 permit 1.1.1.1
access-list 1 deny   172.30.1.0 0.0.0.255
route-map OSPF_FILTER permit 10
match ip address 1
control-plane
end
R3
hostname R3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
ip address 172.30.3.1 255.255.255.252
duplex auto
speed auto
interface Serial0/0
ip address 62.150.2.1 255.255.255.252
clock rate 2000000
ip address 172.30.2.2 255.255.255.252
ip ospf priority 0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
clock rate 2000000
router ospf 1
router-id 3.3.3.3
network 172.30.2.2 0.0.0.0 area 0
router bgp 5500
no synchronization
neighbor 62.150.2.2 remote-as 777
neighbor 172.30.3.2 remote-as 5500
no auto-summary
ip http server
control-plane
end
R4
hostname R4
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 62.150.1.2 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 168.187.1.1 255.255.255.252
clock rate 2000000
router bgp 777
no synchronization
redistribute connected
neighbor 62.150.1.1 remote-as 5500
neighbor 168.187.1.2 remote-as 911
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R5
hostname R5
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 62.150.2.2 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 168.187.2.1 255.255.255.252
clock rate 2000000
router bgp 777
no synchronization
neighbor 62.150.2.1 remote-as 5500
neighbor 168.187.2.2 remote-as 711
no auto-summary
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login
end
R6
hostname R6
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback1
ip address 6.6.6.6 255.255.255.255
interface Loopback60
ip address 160.6.60.1 255.255.255.0
interface Loopback66
ip address 160.6.66.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 168.187.1.2 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 7.30.1.1 255.255.255.252
clock rate 2000000
router bgp 911
no synchronization
redistribute connected route-map ROUTE_FILTER_160
neighbor 7.30.1.2 remote-as 711
neighbor 168.187.1.1 remote-as 777
no auto-summary
ip route 160.6.60.0 255.255.255.0 Null0
ip route 160.6.66.0 255.255.255.0 Null0
ip http server
ip access-list standard BLOCK-160
permit 160.6.60.0 0.0.0.255
permit 160.6.66.0 0.0.0.255
deny   any
route-map ROUTE_FILTER_160 deny 10
match ip address BLOCK-160
set origin igp
route-map ROUTE_FILTER_160 permit 15
control-plane
end
R7
hostname R7
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
interface Loopback1
ip address 7.7.7.7 255.255.255.255
interface Loopback70
ip address 170.7.70.1 255.255.255.0
interface Loopback77
ip address 170.7.77.1 255.255.255.0
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0
ip address 168.187.2.2 255.255.255.252
clock rate 2000000
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
ip address 7.30.1.2 255.255.255.252
clock rate 2000000
router bgp 711
no synchronization
redistribute connected route-map ROUTE_FILTER_170
neighbor 7.30.1.1 remote-as 911
neighbor 168.187.2.1 remote-as 777
no auto-summary
ip route 170.7.7.0 255.255.255.0 Null0
ip route 170.7.77.0 255.255.255.0 Null0
ip http server
ip access-list standard BLOC-170
permit 170.7.70.0 0.0.0.255
permit 170.7.77.0 0.0.0.255
deny   any
route-map ROUTE_FILTER_170 deny 10
match ip address BLOC-170
route-map ROUTE_FILTER_170 permit 20
control-plane
end
Thanking you in Advance....
Sabby
(lab pic is attached)
6 Replies 6
Hi Sarbjit,
Please include keyword subnet in OSPF redistributions and check if problem still persists...
HTH,
Smitesh
PS: Please rate helpful posts...
Thanks for reply....no it is not working...i ping from R2 it is pinging... but when i ping it with source fa0/1 failed....
Hello Sarabjit,
Are you trying to ping from source f0/1 of R2? If yes, then it won't ping. The reason is, your access-list denies the network to be advertised into the eBGP.
Do you see the route for 1.1.1.1/32 on R4 ?
R4#sh ip route
Codes: deleted
Gateway of last resort is not set
     1.0.0.0/32 is subnetted, 1 subnets
B       1.1.1.1 [20/11] via 62.150.1.1, 00:00:05
     168.187.0.0/30 is subnetted, 2 subnets
B       168.187.2.0 [20/0] via 168.187.1.2, 00:00:06
C       168.187.1.0 is directly connected, Serial0/1
     6.0.0.0/32 is subnetted, 1 subnets
B       6.6.6.6 [20/0] via 168.187.1.2, 00:00:06
     7.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
B       7.7.7.7/32 [20/0] via 168.187.1.2, 00:00:06
B       7.30.1.0/30 [20/0] via 168.187.1.2, 00:00:06
     62.0.0.0/30 is subnetted, 1 subnets
C       62.150.1.0 is directly connected, Serial0/0
yh it showing in there
Sabby0115
fixed......i restarted the lab...it works
Sabby0115
Thanks...All for your kind support
