Blinking lights on an Aironet AP3702E
J W
Hey all, I have a strange issue with 2 of my Aironets (2x AP3702E). They are connected to a Cisco 2504 controller. The LED on the front is blinking red, green, off, red, green, off, etc.
According to the documentation that I can see this means that the discovery/join process is in progress. The issue is that the APs are connected to the controller properly (from what I can tell) and even have clients connected to them. I've attempted to reboot the APs, but this does not help. They go down, come back up and re-connect to the controller without issue.
Not that this is a major issue, as the APs appear to be working, but it strikes me as odd behavior. Can anyone shed light on what is going on?
Thank you!
Leo Laohoo
What happens if you remote into the AP?
Is LED flashing enabled on the AP?
Leo Laohoo
