Block rdp access on my switch
ohareka70
Level 3
Level 3
I am trying to block access from switch on vlan7 outbound for tcp/3389.  My IP is 10.230.1.99
interface Vlan7
ip address 10.230.1.220 255.255.255.192
ip access-group BLOCK_RDP in
ip access-group BLOCK_RDP out
ip access-list extended BLOCK_RDP
deny   tcp any any eq 3389
deny   udp any any eq 3389
permit ip any any
access-list 11 permit 10.230.1.99
I am not getting any matches though and RDP access is still working
#sh ip access-lists
Extended IP access list BLOCK_RDP
    10 deny tcp any any eq 3389
    30 deny udp any any eq 3389
    40 permit ip any any (151 matches)
23 Replies 23
You have a host 10.230.1.99/26 in a access port assigned to vlan 7  YES
pointing to a D/G 10.230.70/26 which is the L3 SVI of vlan 7 that resides on the L3 switch - NO the Gateway is 10.230.1.126
and you are testing a RDP connection initiated from this host 10.230.1.99 towards 10.224.3.157- correct ? YES
SVI on the Layer 3 switch
interface Vlan7
description Telem Hut Access VLAN 7
ip address 10.230.1.126 255.255.255.192
Don't you think you are confusing this thread here?
One of the post you VLAN 7 different IP address, another post you have changed to .70
now your post has 10.230.1.126
So we are not sure how many devices you have here, how they are connected.
best to suggest you, Do post full running-config, rather we always assume here.
Are you reading earlier message requested to post traceroute?
BB
Hello
I am wondering if this is an access switch your are trying this on?
Can you confirm is this switch is performing the intervlan routing for your network or is it just an access switch, if the latter then this would be the reason why it isn't  working!
As the access-list needs to be applied to the routing device for your network not any access switch? so either a router or a L3 switch.
Kind Regards
Paul
Q How would you block access to RDP from a layer 2 switch
Just ignore my config and if you could advise on how you would do it
My requirements is that i am on a layer 2 access switch and i want to restrict rdp from the user pcs to the server vlan 10.224.x.x which sits on a different switch in the campus lan
Hello
I suppose you can do it from the host pc that you want to deny access with a fw rule or something but not from the L2 switch
To negate RDP from a host on the network the access-list has to be on a routed (l3) interface of the device performing the routing, The L3 interface on a L2 switch is just for mgt access to the switch nothing more.
Kind Regards
Paul
Thanks for your help on this - I might wait till after hours and try this
Layer 2 switch Delete - ip access-list extended BLOCK_RDP
Layer 3 routing switch
interface Vlan7
permit ip any any
L2 Switch  NO in short answer, ACL required to be applied always @ L3 interface where the traffic passing.
BB
Thanks for your help as well
on a side note, since you are getting hits on 'ip any any', make sure that your RDP host is actually using port 3389 and not a different one...
