Block traffic between two interfaces with out ACL
lchomin
I cannot figure out why my configuration is not working on Cisco 2921.
Basically I try to block traffic from interface DMZ to interface LAN.
On the DMZ interface I added extended ACL:
interface GigabitEthernet0/0.40
ip address 192.168.0.1 255.255.255.0
ip access-group DMZ-OUT out
The access list is very simple:
ip access-list extended DMZ-OUT
deny ip any 10.0.0.0 0.255.255.255
permit ip any any
I would assume that with such configuration all traffic from 192.168.0.0 network should be blocked to network 10.0.0.0 but apparently it's not as still I can ping hosts:
ping 10.0.0.2 source 192.168.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Packet sent with a source address of 192.168.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
What's wrong with my configuration?
Thank you in advance for your valuable help.
Best regards,
Lukasz
5 Replies 5
andrewswanson
Level 7
Level 7
If Gi0/0.40 is your DMZ interface and you want to filter traffic coming into that interface you should apply the ACL inbound:
ip access-group DMZ-OUT in
even with that in place you may run into issues testing the ACL when using ping 10.0.0.2 source 192.168.0.1 :
"Another special note on Cisco ACLs is that ACLs never apply to traffic generated by the router. So, even if you have an inbound and an outbound ACL on a router denying all traffic, the router will still be able to send any packet it wants; the return packet, however, will be blocked as usual."
Above quote from:
http://www.ciscopress.com/articles/article.asp?p=174313&seqNum=4
hth
Andy
Hi Andy,
In fact I want to filter traffic going out from the interface Gi0/0.40 but that doesn't work with my access list.
Thanks a lot for pointing out that testing on the router doesn't take ACLs into consideration. I wasn't aware of that.
Now I'm testing it from a host connected to DMZ network and the result is still the same.
Probably I could define in ACL on my local network (10.0.0.0) but according to best practices filtering should happen as close to the source as possible. So using out ACL on DMZ interface seems to be the best option which unfortunate doesn't work.
Any help why my configuration doesn't work highly appreciated.
Best regards,
Lukasz
Hi Lukasz
If you are looking to deny traffic from your DMZ network 192.168.0.0/24 reaching your LAN network 10.0.0.0/8 then the following should work:
 ip access-group DMZ-IN in
ip access-list extended DMZ-IN
 permit ip any any
hth
Andy
you might want to try local policy routing with a route map.  In your case, it would look like this:
ip access-list extended DROP_DMZ_LAN
 permit ip any any
route-map NO_DMZ_LAN permit 10
 match ip address DROP_DMZ_LAN
Router(config)#ip local policy route-map NO_DMZ_LAN
Hello
A more granular approach would be to to use Control Plane Policing (CoPP)
This will deny any control plane traffic (specified via an acl) destined to the routers interface to be dropped but will allow data plane traffic (transit traffic)
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
class-map match-any STANcm
match access-group 100
policy-map STANpm
class STANcm
drop
control-plane host
service-policy input STANpm
res
Paul
Kind Regards
Paul
