Blocking HSRP messages
htaljaard
Hi all
Is it possible to block workstations on a lan from seeing the HSRP messages going between the routers? The scenario is 2 x 7200 routers configured for HSRP each connected to a 2950, which are in turn connected to each other.
Thanks, Henk
globalnettech
Level 5
Level 5
Hello Henk,
HSRP uses multicast address 224.0.0.2, I guess if you block access from your workstations to this address by means of an access list, that should prevent the workstations from seeing the messages...
GNT
andrew.burns
Level 7
Level 7
Not sure why you'd want to do this - if the workstations are using the hsrp address for that net then the routers need to communicate whether they're active or standby for that net.
However, if it's specifically multicast causing a problem on the workstations then you could always use the "switchport block multicast" on the workstation ports.
HTH - plz rate if useful
Andrew.
The requirement is from the customer that workstations shouldn't see any HSRP messages, etc.
I will try the switchport block mc command.
Thanks for the tip
mahmoodmkl
Level 7
Level 7
and to add something if u block the multicast traffic between u r cores there will be problem as the routers will not be able to exchange hellos which is imp for them to maintain there active/standby relationship.
Mahmood
