12-04-2013 02:26 PM - edited 03-07-2019 04:55 PM
Good afternoon - I am turning up a circuit (4 t1's actually, bonding them together) and I am a little unsure how to do this. This will not be a point-to-point circuit, but 4 t1's bundled into a multilink interface. This is a Cisco 2951 ((C2951-UNIVERSALK9-M), Version 15.1(3)T1) with 3 open wic slots. I have 1 VWIC2-2MFT-T1/E1 card and 2 VWIC2-1MFT-T1/E1 cards.
We are controlling BGP, and this is on an MPLS network.
I think I have it configured correctly, but I was unsure if I put the total bandwith on the multilink interface or if I it on each serial interface respectfully.
I will have it programmed as such:
card type t1 0 1
card type t1 0 2
card type t1 0 3
Controller t1 0/1/0
framing esf
linecode b8zs
clock source line
channel-group 0 timeslots 1-24
Controller t1 0/1/1
framing esf
linecode b8zs
clock source line
Controller t1 0/2/0
framing esf
linecode b8zs
clock source line
Controller t1 0/3/0
framing esf
linecode b8zs
clock source line
interface serial 0/1/0:0
no ip address
encapsulation ppp
multilink
ppp multilink group 1
interface serial 0/1/1:0
no ip address
encapsulation ppp
multilink
interface serial 0/2/0:0
no ip address
encapsulation ppp
multilink
interface serial 0/3/0:0
no ip address
encapsulation ppp
multilink
description 6MB mpls circuit
bandwidth 6176
ip address 1.2.3.4 255.255.255.252
ip route-cache flow
no cdp enable
ppp multilink
ppp multilink fragment disable
Router BGP 65002
bgp log-neighbor-changes
network 192.168.1.0
network 192.168.2.0
redistribute connected
redistribute static
neighbor 1.2.3.3 remote-as 123
neighbor 1.2.3.3 soft-reconfiguration inbound
ip route 0.0.0.0 0.0.0.0 1.2.3.3
Any input is greatly appreciated; I'm pretty sure I have this set up correctly
Thanks!
Joel
Solved! Go to Solution.
12-04-2013 02:33 PM
Looks right to me. Your provider needs to know they're going to bond them with you in order for the multilink interface to come up.
12-04-2013 02:43 PM
That looks right to be. The bandwidth statement goes on the interface with the IP address. It's used by routing protocols and QoS commands to make load calculations.
Are you not running an inside routing protocol like OSPF or EIGRP? You might look int the new EIGRP-OTP stuff. It really helps with BGP based MPLS networks.
12-04-2013 02:33 PM
12-04-2013 02:43 PM
12-04-2013 02:46 PM
John and hypnotoad - Thank you for the quick replies! I am using eigrp, I just failed to put that in the config
