booting can not be recovered from SDA=LOW
fkonig
Hi, i have a cisco 3850 with the following error booting can not be recovered from SDA=LOW.
I can see the error on the console and i can't do anything.
Someone who can help me?
thanks
6 Replies 6
marce1000
 - Difficult one , perhaps related to Software Defined Access setups ? Not sure - I would factory reset and restore the configuration from backup.
 M.
I try factory reset but with the same result
Leo Laohoo
Sounds like the Golden Capsule is corrupt.
Console into the switch and reboot.  Post the entire boot-up proces.
Contact Cisco TAC and arrange for an RMA.
fkonig
Even it doesn't show any light on de front when reset or reboot
