AaronWilbers2035
Beginner
Botched firmware update on 3750 switch, did I brick it?
I have a C3750 switch that I was upgrading to a newer firmware...and had a reboot. Now it the syst light just flashes which means a corrupted image.  When I open a console terminal to the switch I get the following
Loading "flash:c3750-ipservices-mz.122-25.SEB2/c3750-ipservices-mz.122-25.SEB2.bin"...flash:c3750-ipservices-mz.122-25.SEB2/c3750-ipservices-mz.122-25.SEB2.bin: no such file or directory
Error loading "flash:c3750-ipservices-mz.122-25.SEB2/c3750-ipservices-mz.122-25.SEB2.bin"
So I tried to use Xcopy to copy the .bin I was trying to upgrade to in the first place but I got an error about not enough memory.
When I look at flash I see the following,
switch: dir flash:
Directory of flash:/
2 drwx 64 <date> update
3 -rwx 1702 <date> config.text
4 -rwx 5 <date> private-config.text
9122816 bytes available (6876160 bytes used)
Inside the update dir I see the following,
switch: dir flash:/update
Directory of flash:/update/
363 drwx 64 <date> c3750-ipservices-mz.122-50.SE3
switch: dir flash:/update/c3750-ipservices-mz.122-50.SE3
Directory of flash:/update/c3750-ipservices-mz.122-50.SE3/
5 -rwx 6872576 <date> c3750-ipservices-mz.122-50.SE3.bin
But its not letting me delete that file, saying it is a directory.
How do I free up enough space to get the new .bin file installed?  I'm guessing there are left overs from the botched update left.  Or did I brick this?
Thank you.
2 REPLIES 2
marce1000
VIP Mentor
            >...but I got an error about not enough memory
 - Can you provide this error exactly as outputted.
 M.
I appreciate the reply but I was able to delete the files and get the proper version of IOS installed.
Thanks!
