Community Helping Community
4218
Explorer
Bridge 2 Vlans in a Catalyst 3750 Switch
We have 2 trunk ports connected to 2 different Servers Additionally we have a couple of clients that belong to each LAN (access port). Assume Server 1 belongs to VLAN 12 and the Second  Server to VLAN 13.
We have a new requirement that suggests both servers to belong to same Broadcast LAN [a new protocol that works using broadcast messages].
Is it possible to bridge the VLAN 12 and 13 on the same switch (no layer3 router) without making changes on the end nodes?
Regards.
Everyone's tags (2)
3 REPLIES 3
Re: Bridge 2 Vlans in a Catalyst 3750 Switch
If you talking about inter-vlan bridging. Yes it should work fine. You may need to add
#bridge 2 protocol ieee
It's bridge protocol global configuration command to define the type fo STP.
Also I would request you to read the below link to know clear information about VLAN Bridging
Please rate the helpfull posts.
Naidu.
Explorer
Naidu,
What is the link for VLAN Bridging?
Additionally can you brdidge 2 VLANs using crossover cable on the same switch between 2 access ports?
Regards.
You might want to check below links:
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dtbridge.html
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00800a7af6.shtml
There are some configuration example there.
Also:
The second link is about issues that may appear in regard to bridging
Also see the below thread will definetely help you...
https://supportforums.cisco.com/thread/2026541
Naidu.
Content for Community-Ad
