Bug 9300l with firmware 17.09.04a?
Hadronx
I have a stack of switches consisting of 4 x C9300L-48P-4X with firmware 17.09.04a.
Yesterday, one power supply went into a disabled state, but my monitoring server via SNMP didn't detect any anomaly. Indeed, when checking with snmpwalk, that power supply doesn't even appear in the list (switch 1 - power supply A:
I believe this is a bug. Has this happened to anyone else before?
xWatario
pretty sure its not displayed as it got disabled, make sure that you got no physical power issue at the first switch
Mark Elsen
  - You are only listing coEnvMonDupplyStatusDescr  ; and not the OID querying the actual status , but I presume it would be absent in that list too ; therefore you should also be sending all snmp traps from the device to the monitoring server and that server should    be able to handle traps with relevant (alerting) messages (too).
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
