02-13-2017 09:09 PM - edited 03-08-2019 09:19 AM
I am working on asr9k at VIRL simulator. I have configured bundle-ether channel in asr9k routers. Both routers are connected each other. Both are OSPF neighbors and BGP neighbors. I have configured bundle ether channel between them but this budle-ether channel is not coming up.. I have troubleshooted it but no vail. If you have any idea about configuration of bundle-ether channel on IOS-XR, share with me.
configuration is below;
at R2;
R2(config)#interface bundle-ether 10
R2(config-if)#no sh
R2(config-if)#ipv4 address 12.0.0.2 255.255.255.0
R2(config)#interface gi0/0/0/0
R2(config-if)#bundle id 10 mode active
R2(config-if)#no shut
R2(config)#interface gi0/0/0/1
at R1
R1(config)#interface bundle-ether 10
R1(config-if)#no sh
R1(config-if)#ipv4 address 12.0.0.1 255.255.255.0
R1(config)#interface gi0/0/0/0
R1(config-if)#bundle id 10 mode passive
R1(config-if)#no shut
R1(config)#interface gi0/0/0/1
But it is showing down by using "show ip int brief"
02-13-2017 09:59 PM
Hi [@pardeep.sharma8681] ,
Kindly post the configuration of show ether-channel summary command output.
Regards'
02-13-2017 10:20 PM
The command "sh ether-channel summary is feature of IOS-XE, so it will not work in XR. The output of "sh bundle" is below;
RP/0/0/CPU0:R2#sh bundle
Tue Feb 14 06:16:48.341 UTC
Bundle-Ether10
Status: Down
Local links <active/standby/configured>: 0 / 0 / 2
Local bandwidth <effective/available>: 0 (0) kbps
MAC address (source): 0241.837a.a403 (Chassis pool)
Inter-chassis link: No
Minimum active links / bandwidth: 1 / 1 kbps
Maximum active links: 64
Wait while timer: 2000 ms
Load balancing:
Link order signaling: Not configured
Hash type: Default
Locality threshold: None
LACP: Not operational
Flap suppression timer: Off
Cisco extensions: Disabled
Non-revertive: Disabled
mLACP: Not configured
IPv4 BFD: Not configured
Port Device State Port ID B/W, kbps
Gi0/0/0/0 Local Configured 0x0001, 0x0000 1000000
Bundle is in the process of being replicated to this location
Gi0/0/0/1 Local Configured 0x0001, 0x0000 1000000
RP/0/0/CPU0:R2#
02-14-2017 01:38 AM
Actually, I have created ether-channels on switched. I didn't have configured on XR yet. Let me make a lab & then I will let you know.
Regards'
02-14-2017 02:03 AM
thanks for your efforts.
02-14-2017 04:14 AM
04-23-2018 08:29 PM
hey I know it is too late but do you remember how did you resolved the issue.
As i am having a similar in live network.
sagar
04-23-2018 08:29 PM
at R2;
R2(config-if)#no sh
at R1
R1(config-if)#no sh
sagar
