BVI interface port forwarding
sohailmtm
Hi, I am installing ASA 5506-X 9.8(2) but could not setup the port forwarding towards the BVI. Can someone share the config or commands.
luis_cordova
Hi @sohailmtm ,
Review this community discussion on a similar topic:
https://community.cisco.com/t5/firewalls/asa-5506-in-routed-mode-with-bvi-nat-statements/td-p/3353258
It has some information that could be useful to you.
That didi not work for me. I posted some question there but not getting any response.
Ok. i have sorted this by adding following rule. nat (inside_6,outside) source static RDP-Connection-client interface service any RDP-SERVICE1 access-list outside_access_in extended permit object RDP-SERVICE any object RDP-Connection-client Where object network RDP-Connection-client host 192.168.111.10 object service RDP-SERVICE service tcp destination eq 3389 object service RDP-SERVICE1 service tcp source eq 3389 Thanks. Sohail
