bw 4 ping & tracert?
ideasunlmtd
whats the bandwith used by ping and tracert by a single PC?
haroon.shaikh
In both the cases, it is set to 32 bytes for Windows, with Linux its either 56 or 84 bytes of data per ping. Its the same with Tracert as it basically works on ping.
* Please rate if it helps
ramanak
hi,
that depends on the mtu size u set.
ramnath.
