C2921 NAT issue using 3750 Network Module
chadpharris
Hello all,
Desperate need of help. I'm having trouble NATing from private LAN IPs to WAN. My 2921 router is connected to a cable modem on Gi0/0. The 3750 Network Module is connected through backplane on Router-Gi1/0 to Switch-Gi1/0/2. I plan on adding multiple different subnets and corresponding VLANs to the switch but right now I just started with one to see if I could get it to NAT properly; 10.10.30.0/24 subnet.
DHCP server is running on the router and importing DNS servers and Hostname from the cable modem. DHCP is working fine, I just can't get out to the Internet from the hosts off the switch. I can ping all interfaces on the router and switch from the end host.
When I check 'show ip nat translations' I don't see anything. Please help me figure out why I can't NAT out and access the Internet. I've included configs and routing table info below. Thanks a million in advance to anyone that can help!
ROUTER CONFIG:
version 12.4
no parser cache
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log datetime msec show-timezone year
service password-encryption
hostname CPH-RTR-001
boot-start-marker
boot-end-marker
logging buffered 64000 informational
logging monitor informational
enable secret 5 XXXXXXXXXXXXXX
no aaa new-model
resource policy
ip subnet-zero
ip cef
ip dhcp use vrf connected
ip dhcp excluded-address 10.10.30.1 10.10.30.5
ip dhcp pool TEST
   import all
   network 10.10.30.0 255.255.255.0
   default-router 10.10.30.1
ip domain name XXXXXXXXX
ip name-server 4.2.2.2
ip ssh time-out 90
ip ssh authentication-retries 2
ip ssh version 2
username XXXXXXXXX
interface Loopback0
description CPH-RTR-001 Main Loopback Interface
ip address 14.1.1.1 255.255.255.255
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet1/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
no cdp enable
ip classless
ip route 10.10.0.0 255.255.0.0 GigabitEthernet1/0
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 102 interface GigabitEthernet0/0 overload
access-list 102 permit ip 10.10.0.0 0.0.255.255 any log-input
access-list 102 deny   ip any any log-input
control-plane
privilege exec level 15 ssh
privilege exec level 15 connect
privilege exec level 15 telnet
privilege exec level 15 rlogin
privilege exec level 15 show ip access-lists
privilege exec level 1 show ip
privilege exec level 15 show access-lists
privilege exec level 15 show logging
line con 0
logging synchronous
login local
line aux 0
exec-timeout 0 1
login local
no exec
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
exec-timeout 5 0
login local
transport input ssh
transport output none
scheduler allocate 20000 1000
end
SWITCH CONFIG:
version 12.2
no service pad
service timestamps log uptime
hostname CPH-SWT-001
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/2
switchport access vlan 30
switchport mode access
interface FastEthernet1/0/3
description Desktop PC
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
no switchport
ip address 10.10.10.2 255.255.255.0
interface Vlan1
no ip address
interface Vlan30
ip address 10.10.30.1 255.255.255.0
ip helper-address 10.10.10.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.10.1
no ip http server
control-plane
line con 0
logging synchronous
line vty 0 4
logging synchronous
login
line vty 5 15
logging synchronous
login
end
ROUTER - Routing Table (ISP IPs replaced with example IPs):
CPH-RTR-001#show ip route
Gateway of last resort is 95.5.5.1 to network 0.0.0.0
     95.0.0.0/21 is subnetted, 1 subnets
C       95.5.5.0 is directly connected, GigabitEthernet0/0
     135.254.0.0/32 is subnetted, 1 subnets
S       135.254.100.33 [254/0] via 95.5.5.1, GigabitEthernet0/0
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
S       10.10.0.0/16 is directly connected, GigabitEthernet1/0
C       10.10.10.0/24 is directly connected, GigabitEthernet1/0
     14.0.0.0/32 is subnetted, 1 subnets
C       14.1.1.1 is directly connected, Loopback0
S*   0.0.0.0/0 [1/0] via 95.5.5.1
SWITCH - Routing Table:
CPH-SWT-001#show ip route
Gateway of last resort is 10.10.10.1 to network 0.0.0.0
     10.0.0.0/24 is subnetted, 2 subnets
C       10.10.10.0 is directly connected, GigabitEthernet1/0/2
C       10.10.30.0 is directly connected, Vlan30
S*   0.0.0.0/0 [1/0] via 10.10.10.1
ROUTER - IP Interface Brief:
CPH-RTR-001#show ip int bri
Interface                  IP-Address      OK? Method Status                Protocol
GigabitEthernet0/0         95.5.7.244    YES DHCP   up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  administratively down down
GigabitEthernet1/0         10.10.10.1      YES NVRAM  up                    up
NVI0                       unassigned      YES unset  up                    up
Loopback0                  14.1.1.1        YES NVRAM  up                    up
SWITCH - IP Interface Brief:
CPH-SWT-001#show ip int bri
Vlan1                  unassigned      YES NVRAM  up                    down
Vlan30                 10.10.30.1      YES NVRAM  up                    up
FastEthernet1/0/2      unassigned      YES unset  up                    up
FastEthernet1/0/3      unassigned      YES unset  down                  down
FastEthernet1/0/4      unassigned      YES unset  down                  down
FastEthernet1/0/5      unassigned      YES unset  down                  down
FastEthernet1/0/6      unassigned      YES unset  down                  down
FastEthernet1/0/7      unassigned      YES unset  down                  down
FastEthernet1/0/8      unassigned      YES unset  down                  down
FastEthernet1/0/9      unassigned      YES unset  down                  down
FastEthernet1/0/10     unassigned      YES unset  down                  down
FastEthernet1/0/11     unassigned      YES unset  down                  down
FastEthernet1/0/12     unassigned      YES unset  down                  down
FastEthernet1/0/13     unassigned      YES unset  down                  down
FastEthernet1/0/14     unassigned      YES unset  down                  down
FastEthernet1/0/15     unassigned      YES unset  down                  down
FastEthernet1/0/16     unassigned      YES unset  down                  down
FastEthernet1/0/17     unassigned      YES unset  down                  down
FastEthernet1/0/18     unassigned      YES unset  down                  down
FastEthernet1/0/19     unassigned      YES unset  down                  down
FastEthernet1/0/20     unassigned      YES unset  down                  down
FastEthernet1/0/21     unassigned      YES unset  down                  down
FastEthernet1/0/22     unassigned      YES unset  down                  down
FastEthernet1/0/23     unassigned      YES unset  down                  down
FastEthernet1/0/24     unassigned      YES unset  down                  down
GigabitEthernet1/0/1   unassigned      YES unset  down                  down
GigabitEthernet1/0/2   10.10.10.2      YES NVRAM  up                    up
cadet alain
log keyword is not supported in NAT ACLs so just edit your ACL 102 by removing the  log-input keyword and it should be working.
One little remark, you don't need a static route for the 10.10.0.0/16 network  and you should avoid  static routes pointing to an ethernet exit interface.
Alain
cadet alain
Alain
I can't believe it was that simple! Thanks so much for your help.
