C2960S stack and number of spanport sessions
pbogaerts
What is the number of spanport sessions that you can configure on a stack of c2960S switches, could not find an answer.
maher0977
Hi dear friend
Every C2960S has up to 66 SPAN sessions, each SPAN session has up to 64 span destination ports and up to number of available ports on the switches for source span port.
When you use Stack, only the control panel protocols and technologies will be shared to increase the availability and performance.
SPAN is not related to this sharing, it implies you can use 66x2 = 132 SPAN sessions when you use stack between two C2960Ss.
Best Regards.
Eng. Maher Al-Jurf
CCIE R&S (CCIE#42758)
Senior Network and Security Engineer
Mob. +966-545958090
E-mail: maher7783@gmail.com
