C3650-48-L-E
mauidtools
We are currently specking (33) Crestron DM-NVX-350 and each one requires (1) gigabit to endcode/decode
Does the C3650 have a backplane to support 33gig?
as far as I recall, the 3650 has a 32Gigabit backplane (both the 24 and the 48 port version). Stacking obviously increases the throughput...
bruce.hodge
You can tune the NVX's down to 450Mb/s stream without to much loss of performance.
Unless you are doing medial or mapping 450 should do the job.
They are always on devices, look at IGMP filtering if your layer three interface is not on the switch.
The up-links between switches in the same VLAN need to allow for the traffic as well.
Good Luck!
