C3650-48FQM - cable diagnostic tdr - strange output
joerg.hohn
we have some C3650-48FQM which shows strange output on "show cable-diagnostics tdr int gi x/y/z"
All connections are 4 wire (2 pair) connections.
switch#sho cable-diagnostics tdr int gi1/0/38
TDR test last run on: August 18 10:39:48
Interface   Speed Local pair Pair length        Remote pair Pair status
Gi1/0/37    auto  Pair A     0    +/- 10 meters N/A         Normal
                  Pair B     0    +/- 10 meters N/A         Normal
                  Pair C     N/A                N/A         Normal
                  Pair D     0    +/- 10 meters N/A         Normal
Gi1/0/38    100M  Pair A     50   +/- 10 meters N/A         Normal
                  Pair B     183  +/- 10 meters N/A         Normal
                  Pair C     4    +/- 5  meters N/A         Open
                  Pair D     4    +/- 5  meters N/A         Open
switch#sho cable-diagnostics tdr int gi1/0/39
TDR test last run on: August 18 10:52:48
Gi1/0/39    100M  Pair A     44   +/- 10 meters N/A         Normal
                  Pair B     44   +/- 10 meters N/A         Normal
                  Pair C     7    +/- 10 meters N/A         Normal
                  Pair D     5    +/- 10 meters N/A         Normal
Any suggestions? Is this a bug?
greetings
Jörg
5 Replies 5
balaji.bandi
int gi1/0/38
i would investigate this Physical patches cables, shows more distance ? is this correct ?
Good documentation to understand :
https://community.cisco.com/t5/networking-documents/how-to-use-time-domain-reflectometer-tdr/ta-p/3119327
BB
Leo Laohoo
What firmware is the switch running on?
The switches are running 16.9.4
That is one dodgy output.  Personally, I would not trust an output like that.
What is the uptime of the switch?
thanks for all your answers and questions.
The switch was booted when checking this but the output was the same strange thing as before the reboot.
