C3750, port isolation
perpaal
Hi I need to set up a guest network, where clients on each port should only be allowed to talk to gateway. How would a best achieve this on a Cisco Catalyst 3750?
6 Replies 6
Mark Malone
just an option you could create a layer 3 vlan on the 3750 assign the ports you want to this vlan as layer 2 and then lock down the interface vlan using access-lists so it cannot talk to any other vlans or devices and only be able to get to the gateway , you could go another route and use private vlan setup community or isolated ports depending how strict you want to be
How would a private VLAN setup for this look like? The network spans over 3pcs 3750 switches.
Heres the link explaining how to configure it for 3750 there's not too much in it you probably want community port setup so they can speak to each other in same vlan but no 1 else , isolated will lock the ports down completely
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3750/software/release/12-2_55_se/configuration/guide/scg3750/swpvlan.html
Hello
Pvlans are indeed another way to isolate switchports in varous vlans over multiple switches but it does require some configuration.
Promiscuous port - belongs to primary vlan and all plvan ports can communicate with it
Primary vlan - All ports in plvan are part of this vlan
Community vlans - secondary vlan allowed to communicate with other port in its vlan and the promiscuous port in the primary vlan
isolated vlans - secondary vlan that can NOT communicate to any other port in any vlans other than the promiscuous port in hte primary vlan
Lets say the vlans span over 2 switches ( SW1- SW2)
SW1
promiscuous port = fa0/1
vlan 10 primary
vlan 20 communitiy
vlan 30 comunitity
vlan 40 isolated
1)
create trunks that are to be used ( if applicable) On all switches
Note: vtp mode of switch needs to be transparent ( before or after vlan creation and propergation ( again if applicable)
vtp mode transparent
2) create the L2 vlans and assocate the private vlans
 vlan 10, 20,30,40
exit
vlan 10
private-vlan primary
vlan 20-30
private vlan community
vlan 40
private-vlan isolated
 3) assoication secondaries to primary vlan
vlan 10
private-vlan assoication add 20,30,40
sh vlan private-vlan
Primary Secondary Type              Ports
10      20        community
10      30        community
10      40        isolated
4) assiocate a promiscuous port and map the secondary vlans to it
 (not applicable on every switch only on the switch  the promisuous port is attached to)
int fa0/1
switchport mode private-vlan promiscuos
switchport private-vlan mapping 10 20,30,40
10      20        community         Fa0/1,
10      30        community         Fa0/1,
10      40        isolated          Fa0/1,
 5) associate host to the vlans
int fa0/2
switchport mode private-vlan host
switchport private-vlan host-association 10 20
int fa0/3
int fa0/4
switchport private-vlan host-association 10 30
int fa0/5
switchport private-vlan host-association 10 40
10      20        community         Fa0/1, Fa0/2,Fa0/3
10      30        community         Fa0/1, Fa0/4
10      40        isolated          Fa0/1, Fa0/5
Layer 3 interfaces - so secondary vlan 20 30 can comunicate with each other
Switch(s)
1)
int vlan 10 ( this is the primary L3 interface relating to Vlan 10  L2 primary vlan)
ip add 220.1.1.100 255.255.255.0
ip add 230.1.1.100 255.255.255.0 secondary
private-vlan mapping 20,30
ip routing
Hosts
the secondary hosts need to be in the same ip range has the SVI l3 interface with a default-gateway
assigned
interface x/x
 description Pvlan 20 Community port
interface x/x
 description Pvlan 30 Community port
cco doc
hope this helps
res
Paul
Kind Regards
Paul
Hello
Is this relating to the one switch? - if so the easiest way would be switchport protected command
Any ports with this enabled wont be able to comunicate with each other
int x/x
res
Paul
Kind Regards
Paul
It will be spanning over 3 switches.
