03-11-2015 03:48 PM - edited 03-07-2019 11:03 PM
Does the C3750E support advanced layer 3 and OSPF? If not, is there a license upgrade and what is that part number. If already capable, how do you enable?
Show ver:
rpswch0100#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 18:14 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
rpswch0100 uptime is 4 weeks, 3 days, 20 hours, 27 minutes
System restarted at 14:05:47 PST Sat Feb 7 2015
System image file is "flash:/c3750e-universalk9-mz.122-55.SE5/c3750e-universalk9-mz.122-55.SE5.bin"
Thank You,
Mike R
03-11-2015 04:03 PM
● LAN Base: Enables basic Layer 2 forwarding and IPv4/IPv6 switch management.
● IP Base: Enables Layer 2 forwarding, IPv6 management, and basic Layer 3 routing, including Enhanced Interior Gateway Routing Protocol (EIGRP) stub and Protocol Independent Multicast (PIM) stub mode.
● IP Services: Includes IP Base and enables advanced IPv4/IPv6 Layer 3 routing such as EIGRP, Open Shortest Path First (OSPF), WCCP, VRF-lite, PBR, and IPv4 multicast routing.
03-11-2015 04:05 PM
rpswch0100#sh license
Index 1 Feature: ipservices
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
License Count: Non-Counted
Index 2 Feature: ipbase
Period left: Life time
License Type: Permanent
License State: Active, In Use
License Priority: Medium
Index 3 Feature: lanbase
Period left: 0 minute 0 second
03-11-2015 04:19 PM
Leo,
Thanks for responding. I am not technical but it looks like they have the correct license but it is not in use? Can they call TAC to enable?
thanks,
Mike R
03-11-2015 04:28 PM
Mike
That's only an evaluation license so even if it is activated it won't be permanent.
Jon
03-11-2015 05:17 PM
rpswch0100#sh license Index 1 Feature: ipservices Period left: 8 weeks 4 days License Type: Evaluation License State: Active, Not in Use, EULA not accepted License Priority: None License Count: Non-Counted
I agree with Jon.
Your IP Service license in in "evaluation". And you currently can't use it because the EULA hasn't been accepted.
The evaluation license will bomb out in "8 weeks 4 days" and will revert back to IP Base.
03-11-2015 04:26 PM
Mike
You are running IP Base.
However if it just OSPF you need there is a feature in your IOS version called OSPF for routed access which supports a limited version of full OSPF.
See this link for details (search for "routed access") -
it may be enough for what they need.
Jon
03-11-2015 04:28 PM
Show license will tell you what license is active. Advanced L3 will need a license. You can look at the part numbers at the following link:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3750-e-series-switches/QandA_Software_Activation.html
John
