08-11-2020 12:06 AM
Hello Cisco community
Purchased single Catalyst Switch C3750G-WS24-S25 with integrated wireless controller. Had to do password reset, and by mistake deleted some files and folders from flash: while being in rommon mode. Also wanted to shorten boot time and removed stack provision or something like that. Hence post reboot switch works fine, but alternating amber green SYST led came in. I found a note on cisco website that in my case it it related to wireless controller not working properly.
Question is - how can I fix that? Does anyone has same device and can share with me all the files on flash:? Could be with IOS as well. Will this help? Thank you in advance!
08-11-2020 02:57 AM
But WHY????? The switch is so old the firmware has already been taken down from the Cisco website.
08-11-2020 02:59 AM
Still a good device for home lab. Very affordable.
08-11-2020 03:28 AM
08-11-2020 04:51 AM
Appreciate your opinion Leo.
But still require some help on the topic.
08-11-2020 04:54 AM
08-11-2020 05:14 AM
Leo, I am able to get IOS c3750-ipbasek9-mz.150-2.SE11 but not sure if that will be enough. Will try to update tonight.
I was hoping someone has same device and can share flash content.
08-15-2020 03:33 AM
Thank you all. Problem with integrated WLC identified. Failed DDR module. Brand new module found for magical price of $1. Will keep you posted once replace module.
Thank you @m.kieffer for below post:
https://community.cisco.com/t5/other-wireless-mobility-subjects/wlc-4402-boot-failure/td-p/2469288
