10-17-2013 01:25 PM - edited 03-07-2019 04:05 PM
I try to enable bgp on our C3750 that 12.2(55)SE1. It has "ipbase" license. And I am getting the following error message when trying to enable bgp
flex_3750_172_24_43_(config)#router bgp 2000
Protocol not in this image
According to the documentation, "ipbase" license should allow BGP. Do I need to upgrade to better version?
The "show version" output as follows:
flex_3750_172_24_43_2#sho ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 02-Dec-10 06:08 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
flex_3750_172_24_43_2 uptime is 2 years, 18 weeks, 6 days, 5 hours, 24 minutes
System restarted at 10:52:50 cst Wed Jun 8 2011
System image file is "flash:/c3750e-universalk9-mz.122-55.SE1/c3750e-universalk9-mz.122-55.SE1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-48 (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID FDO1517P0BW
Last reset from power-on
7 Virtual Ethernet interfaces
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : E8:B7:48:C1:44:80
Motherboard assembly number : 73-12552-05
Motherboard serial number : FDO15171JB2
Model revision number : A0
Motherboard revision number : B0
Model number : WS-C3750X-48T-S
Daughterboard assembly number : 800-32727-01
Daughterboard serial number : FDO1517174Y
System serial number : FDO1517P0BW
Top Assembly Part Number : 800-31326-02
Top Assembly Revision Number : B0
Version ID : V02
CLEI Code Number : COMJT00ARB
Hardware Board Revision Number : 0x03
Switch Ports Model SW Version SW Image
* 1 54 WS-C3750X-48 12.2(55)SE1 C3750E-UNIVERSALK9-M
10-17-2013 03:39 PM
BGP is not supported on IP base only a few routing protocols. You need to upgrade to IP Services to get BGP.
Table in link shows what is supported.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps8802/ps6969/ps5012/product_bulletin_c25-614546_ps10081_Products_Bulletin.html
04-08-2016 04:15 PM
Thanks Phillip, came across this scenario. This post has helped a lot !!!!
10-17-2013 07:29 PM
Hi Pat Liu,
Phillip is correct. ip base on 3750X only supports static, and some routing protocols, but limited functionalities.
For an overview of the 3 diff licenses used in L3 switches now:
LAN-base - L2 functionalities only
IP-base - has L3, but Static, RIP, Stub EIGRP, OSPF with limited routes, Stub PIM, complete QoS,Security
IP-services - has all of IP-base, plus full L3 functionalities just like in routers (OSPF, EIGRP, BGP, ISIS, PbR, EEM, VRF-lite, etc.)
Refer to this document for the full documentation and license upgrade procedures.
Upgrade procedure summary:
1. Get your PAK File.
2. Enter PAK number on cisco website with the Serial number of chassis:
(Search: licensing.cisco.com)
https://tools.cisco.com/SWIFT/LicensingUI/Home
3. you will receive .LIC file via email.
4. Upload .LIC file and activate license on the device.
Please don't forget to rate answers.
Hope this helps!
04-08-2016 04:17 PM
Thanks so much, s.lachica
