C3750X ipbase to ipservice
slyfox
Have stack with C3750X-24,C3750X-48 and C3750X-12s under ipbase.
What license part No I need to have ipservice ?
version change due to ebgp and ibgp functionality required
Reza Sharifi
see table-20 in the datasheet:
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3560-x-series-switches/data_sheet_c78-584733.html
I also recommend contacting your Cisco SE or the partner's SE before upgrading, as license upgrade to "IP services" can get complicated and can be expensive.
5 Replies 5
Reza Sharifi
balaji.bandi
in a stack -  master switch only need ip service licenses ( to get more features), rest can be ip base license.
I also suggest good community document for your reference :
https://community.cisco.com/t5/network-architecture-documents/licensing-on-2900-3500-3700/ta-p/3130037
BB
@balaji.bandi what if master breaks down?
I don't recommend upgrading the master only. If you do that and the master fails, you will have downtime and lose all your BGP, VRF, and any other feature that is enabled by IP services.  It will be a disaster when things break at 2:00 AM.
Sorry for the confusion here ....let me correct it here, i mean to master and slave have ipservice, and reset of member in stack
will be ip base.
make sense ?
BB
