C3850-Fiber Module
Anukalp S
I need your help in understanding fiber module on 3850 switch. I have recently added fiber module on 3850 switch and I can see below ports visible after adding module. Cant I use all four TenGig interfaces as uplink ports for 10Gig connectivity with 10Gig SFPs.
Need clarification..please share your ideas.
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
acampbell
It depends on the module part number you purchased.
see this link for the information:-
https://supportforums.cisco.com/document/9879251/3850-understanding-interface-configuration-nm-modules
Alex
Regards, Alex. Please rate useful posts.
Reza Sharifi
As Alex noted, it depends on the type of switch you are using.
Have a look at table-3 in this link.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3850-series-switches/data_sheet_c78-720918.html
