11-03-2015 12:57 PM - edited 03-08-2019 02:33 AM
I have cisco WS-C3850-24P switch which is running image cat3k_caa-universalk9. Now I have installed a 10G network module C3850-NM-8-10G Module m.y problem is10G switch intereface are not comming up.
any idea why it was not coming up or i need to configure any thing here.
11-03-2015 02:01 PM
What version of switch do you have? Can you post a "Show Version"? Reason I ask, the C3850-NM-8-10G is only supported on the following switches.
This is supported on the following switch models:
WS-C3850-12X48U
WS-C3850-24XS
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/hardware/installation/guide/b_c3850_hig/b_c3850_hig_chapter_011.html
From a different Cisco link..
Note: The C3850-NM-4-10G module is supported only on the 48-port Gigabit Ethernet models or on the 12-port or higher 10 Gigabit Ethernet models. The C3850-NM-8x10G and C3850-NM-2x40G modules are supported on the 24-port and 48-port multigigabit switches and also on the 24-port 10G SFP+ switch model. The C3850-NM-4-1G and C3850-NM-2-10G modules are not supported on the 12-port and 24-port SFP+ models.
11-03-2015 02:40 PM
The module you have is only supported in the following switch models: These are the new Cisco 3850 MGig Switches
WS-C3850-24XU
WS-C3850-12X48U
