07-18-2011 08:19 AM - edited 03-07-2019 01:16 AM
All,
i have a cisco 4506 that is producing the error message above. I tried the following commands but can't seem to find port 183. Any ideas?
sh platform mapping ports
sh snmp mib ifmib ifindex
Solved! Go to Solution.
07-19-2011 09:56 AM
you should do hw-module reset, the sup was not able to communicate with the line card 4 for some reasons. Though i guess the show module should have been showed the module 4 as unknown, but in this case it has not listed it.
Did the switch reset/reboot by itself when this happened?
Are there any crash logs ?
There is no risk reseting a module, except downtime of 5-10mins for the reset i believe.
Manjunath
07-19-2011 10:55 AM
Run this command exactly matching the case...
show platform chassis | inc pimPhyport
This will show this......
pimPhyport Gi3/17(64)
find the port that has (183) and you will find the port you are looking for.
Mike
07-19-2011 06:53 AM
Hi.
Please do a soft reset of the modulke which is showing this error.
'hw-module slot 4 reset'
Kindly post the IOS version which you are running. There are many known bugs for these
error messages. I can look for it if anything matches with you issue.
Cheers
Sweta
*Please rate the content if it helped you.
07-19-2011 07:19 AM
What are the risks of resetting the module? I aslo don't see module 4 listed...
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 2 1000BaseX (GBIC) Supervisor(active) WS-X4515 JAE074006YL
2 6 1000BaseX (GBIC) WS-X4306 JAE05240154
3 6 1000BaseX (GBIC) WS-X4306-GB JAE0829PXMJ
5 48 10/100/1000BaseT (RJ45) WS-X4448-GB-RJ45 JAB06130AM2
M MAC addresses Hw Fw Sw Status
1 0013.60bc.f380 to 0013.60bc.f381 3.0 12.1(12r)EW 12.2(20)EWA Ok
2 0002.16e8.62b8 to 0002.16e8.62bd 2.0 Ok
3 000b.5f41.5c86 to 000b.5f41.5c8b 2.2 Ok
5 0005.5fa3.e8b0 to 0005.5fa3.e8df 1.0 Ok
The version is below:
cat4000-i9k91s-mz.122-20.EWA.bin
07-19-2011 09:56 AM
Manjunath
07-19-2011 10:07 AM
I am not sure when the messages started as I just took this over. But the switch has been up for 29 weeks. I will reset the module this evening (i.e EST time).
07-19-2011 10:44 AM
I also just found out that the switch doesn't have anything in slot 4. Slot 4 and 6 are empty.
07-19-2011 10:55 AM
Mike
07-19-2011 12:01 PM
I am sorry but the correct answer is from Mike. I made a mistake by clicking on Manju. Thanks all for your help. I very much appreciated it.
07-19-2011 11:12 AM
LOL, my bad for assuming you had put line card on slot 4......hehe
Do you see any port in disabled/blocked status Tshi M?
especially the port which Mike helped to identify.
07-19-2011 11:55 AM
No worries Manju...I am working remotely so I don't have a visual of the device. In any case, Mike command helped me track down the port (see below).
pimPhyport Gi5/40(183)
I checked the port and it has a lot of output drops. The switchport is reporting at 1000/full. So, I will ask the user to move to another port and see if this still happening.
Total output drops: 576726
Thanks Mike, I will keep you posted.
07-19-2011 12:13 PM
Glad I could help. I would also clear the counters to see if they increment.
When I had this happen it actually turned out to be a bad module. If you move them to the same module and you still have the same issue, try another module.
Mike
