C6509 Sup2T VoIP QoS policy
Wayne Ficklin
I'm tasked with establishing a VoIP policy for our C6509 w/ Sup2T supervisor.  Ultimately, we'd like to avoid QoS, but that doesn't seem to be the reality of our situation, so we'd like to minimally apply QoS ...and only to VoIP traffic (with an eye toward Video eventually).  The thinking being that cos5: voip media, cos4:voip signaling/video.
Here is a (doctored) QoS policy for 1p3q8t ports I found at: http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-0SY/configuration/guide/15_0_sy_swcg/qos_policy_based_queueing.html#wp1025940
class-map type lan-queuing match-any c_map_cos_4
  match cos 4
class-map type lan-queuing match-any c_map_cos_5
  match cos 5
policy-map type lan-queuing p_map_1p3q8t
class c_map_cos_5
  priority
class c_map_cos_4
  bandwidth remaining percent 20
  queue-buffers ratio 10
class class-default
  bandwidth remaining percent 80
  queue-buffers ratio 80
Before I go ahead with this, does anything jump out as wrong or short-sighted about this policy?
Thanks for your input!
Mark Malone
hi
sup2t is already trusting dscp/cos by default if i remember right and if your using cisco phones they will set the dscp at source and the 6500 will trust it , voice is already being prioritized in the mods , did you check the queuing before applying anything ?---show queuing interface gx/x ----cos 5 is in the priority queue already for ef voice traffic
From one of my 6500s nothing applied to it in terms of qos or queuing and its on by default running sup2t with 6748s trusting cos/dscp
#sh queuing Interface G1/7/1
Interface GigabitEthernet1/7/1 queueing strategy:  Weighted Round-Robin
  Port QoS is enabled globally
  Queueing on Gi1/7/1: Tx Enabled Rx Enabled
Trust boundary disabled
  Trust state: trust DSCP
  Trust state in queueing: trust COS
  Extend trust state: not trusted [COS = 0]
  Default COS is 0
    Queueing Mode In Tx direction: mode-cos
    Transmit queues [type = 1p3q8t]:
    Queue Id    Scheduling  Num of thresholds
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:  100[queue 1] 150[queue 2] 200[queue 3]
    queue-limit ratios:     50[queue 1]  20[queue 2]  15[queue 3]  15[Pri Queue]
    queue tail-drop-thresholds
    1     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    2     70[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    3     100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
    queue random-detect-min-thresholds
      1    40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
      2    40[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
      3    70[1] 70[2] 70[3] 70[4] 70[5] 70[6] 70[7] 70[8]
    queue random-detect-max-thresholds
    WRED disabled queues:
    queue thresh cos-map
    1     1      0
    1     2      1
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1      2
    2     2      3 4
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1      6 7
    3     2
    3     3
    3     4
    3     5
    3     6
    3     7
    3     8
    4     1      5
    Queueing Mode In Rx direction: mode-cos
    Receive queues [type = 1q8t]:
       01         WRR                 08
    queue-limit ratios:    100[queue 1]
    1     50[1] 50[2] 60[3] 60[4] 80[5] 80[6] 100[7] 100[8]
    1     1      0
    1     2
    1     3      1 2 3 4
    1     4
    1     5      6 7
    1     6
    1     7      5
    1     8
  Packets dropped on Transmit:
    BPDU packets:  0
    queue              dropped  [cos-map]
    1                    11153  [0 1 ]
    2                        0  [2 3 4 ]
    3                        0  [6 7 ]
    4                        0  [5 ]
  Packets dropped on Receive:
    BPDU packets:  0
    1                        0  [0 1 2 3 4 6 7 5 ]
Mine's a bit different than yours
6509#show queueing int g1/1/1
Interface GigabitEthernet1/1/1 queueing strategy: Weighted Round-Robin
Port QoS is disabled globally
Queueing on Gi1/1/1: Tx Disabled Rx Disabled
Default COS is 0
01 WRR 08
02 WRR 08
03 WRR 08
04 Priority 01
WRR bandwidth ratios: 100[queue 1] 0[queue 2] 0[queue 3]
queue-limit ratios: 100[queue 1] 0[queue 2] 0[queue 3] 0[Pri Queue]
1 100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
2 100[1] 100[2] 100[3] 100[4] 100[5] 100[6] 100[7] 100[8]
WRED disabled queues: 1 2 3
1 1 0 1 2 3 4 5 6 7
1 2
1 3
1 4
1 5
1 6
1 7
1 8
2 1
2 2
2 3
2 4
2 5
2 6
2 7
2 8
3 1
3 2
3 3
3 4
3 5
3 6
3 7
3 8
4 1
Receive queues [type = 2q8t]:
01 WRR 08
02 WRR 08
1 1 0 1 2 3 4 5 6 7
1 2
1 3
1 4
1 5
1 6
1 7
1 8
2 1
2 2
2 3
2 4
2 5
2 6
2 7
2 8
BPDU packets: 0
1 23393 [0 1 2 3 4 5 6 7 ]
BPDU packets: 0
1 0 [0 1 2 3 4 5 6 7 ]
Yes there all being put into 1 queue so even though trusted its not separating them , so you will need to use auto qos voip trust under the interface and then the values will be moved into different queues in queuing
When you do this on 1 port the whole module will get the wrr queuing its auto like that like below
interface GigabitEthernet1/6
 switchport
 switchport access vlan 160
 platform qos trust cos
 wrr-queue bandwidth 20 100 200
 priority-queue queue-limit 5
 wrr-queue queue-limit 65 15 15
 wrr-queue random-detect min-threshold 1 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 2 70 100 100 100 100 100 100 100
 wrr-queue random-detect min-threshold 3 40 40 50 50 60 60 70 70
 wrr-queue random-detect max-threshold 1 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 2 100 100 100 100 100 100 100 100
 wrr-queue random-detect max-threshold 3 70 70 80 80 90 90 100 100
 wrr-queue cos-map 2 1 1 2
 wrr-queue cos-map 3 5 3 4
 wrr-queue cos-map 3 7 6 7
 auto qos voip trust
 spanning-tree portfast edge
 spanning-tree cost 3019
 ip dhcp snooping limit rate 7
end
#sh queueing interface g1/6
Interface GigabitEthernet1/6 queueing strategy:  Weighted Round-Robin
  Queueing on Gi1/6: Tx Enabled Rx Enabled
  Trust state: trust COS
  Default COS is 0
       01         WRR                 08
       02         WRR                 08
       03         WRR                 08
       04         Priority            01
    WRR bandwidth ratios:   20[queue 1] 100[queue 2] 200[queue 3]
    queue-limit ratios:     65[queue 1]  15[queue 2]  15[queue 3]   5[Pri Queue]
      3    40[1] 40[2] 50[3] 50[4] 60[5] 60[6] 70[7] 70[8]
      3    70[1] 70[2] 80[3] 80[4] 90[5] 90[6] 100[7] 100[8]
    1     1      0
    1     2
    1     3
    1     4
    1     5
    1     6
    1     7
    1     8
    2     1      1 2
    2     2
    2     3
    2     4
    2     5
    2     6
    2     7
    2     8
    3     1
    3     2
    3     3
    3     4
    3     5      3 4
    3     6
    3     7      6 7
    3     8
    4     1      5
    Receive queues [type = 1q2t]:
       1         Standard            2
    1     80[1] 100[2]
    1     1      0 1 2 3 4
    1     2      5 6 7
    BPDU packets:  0
    queue thresh             dropped  [cos-map]
    1     1                       0  [0 ]
    2     1                       0  [1 2 ]
    3     5                       0  [3 4 ]
    3     7                       0  [6 7 ]
    4     1                       0  [5 ]
    BPDU packets:  0
    1     1                       0  [0 1 2 3 4 ]
    1     2                       0  [5 6 7 ]
