C6509-SUP720 installation issue
I have replaced the new SUP720 card in chassis c6509 but it was going to rommon mode again and again after selecting the right image .
Kindly find the below error messages .
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x4382fd1c
PC = 0x4040e934, Cause = 0x1020, Status Reg = 0x34008102
rommon 8 >
rommon 8 >
rommon 3 > dir bootdisk:
Initializing ATA monitor library...
Directory of bootdisk:
2      80893476  -rw-     s72033-advipservicesk9_wan-mz.122-18.SXF16.bin
9120    33554432  -rw-     sea_log.dat
33424    273170    -rw-     route
22292    80858180  -rw-     s72033-adventerprisek9_wan-mz.122-18.SXF15a.bin
13973    45616     -rw-     30
13979    78426628  -rw-     s72033-advipservicesk9_wan-mz.122-33.SXH5.bin
33458    7726      -rw-     crashinfo_20190819-070044-UTC
33459    226343    -rw-     crashinfo_20190819-073619
We have tried boot the supervisor with latest IOS s72033-adventerprisek9-mz.151-2.SY12.bin and supervisor going to rommon mode due to RP failed to boot.
Kindly find the below log for your reference.
rommon 23 > boot disk0:s72033-adventerprisek9-mz.151-2.SY12.bin
Writing crashinfo to bootflash:crashinfo_SP_20190819-115811-UTC
=== Flushing messages (11:58:13 UTC Mon Aug 19 2019) ===
Buffered messages:
Queued messages:
*Aug 19 11:58:13.415: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug 19 11:58:11.907: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Aug 19 11:58:11.911: %PFREDUN-SP-4-AUTOBOOT: Disable autoboot for Supervisor in slot 8
*Aug 19 11:58:11.911: %PFREDUN-SP-6-ACTIVE: Sup in slot 8 is crashing due to RP failed to boot
*Aug 19 11:58:11.939: SP: Failed to send heartbeat poison message
*Aug 19 11:58:14.499: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Aug 19 11:58:13.907: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Aug 19 11:58:14.499: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** System received an unknown failure ***
signal= 0x0, code= 0x0, context= 0x452af624
PC = 0x41d81e64, Cause = 0x1820, Status Reg = 0x34008102
rommon 24 >
please help me out in this issue
marce1000
 - Forced crash  can have several causes , such as corrupt image or hardware problem :
                  https://www.cisco.com/c/en/us/support/docs/routers/7500-series-routers/26145-crashes-swforced-troubleshoot.html
 M.
-- ' 'Good body every evening' ' this sentence was once spotted on a logo at the entrance of a Weight Watchers Club !
Hi Marce,
Thank you for a quick response . what will be the hardware problem in forced crash.
Giuseppe Larosa
Hello Prathamesh,
you should read the release notes for the target release
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/15-1SY/release_notes.html
You may need to upgrade the ROMMON on your sup 720 before being able to load the new image.
Hope to help
Giuseppe
