We have a C6509,have a WS-X6748-SFP,show power,Oper State:off (not supported):
NJ-GL-ASW-2.YPT.C6509#show power
system power redundancy mode = redundant
system power total = 2771.16 Watts (65.98 Amps @ 42V)
system power used = 1590.54 Watts (37.87 Amps @ 42V)
system power available = 1180.62 Watts (28.11 Amps @ 42V)
Power-Capacity PS-Fan Output Oper
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 2771.16 65.98 OK OK on
2 WS-CAC-3000W 2771.16 65.98 OK OK on
Pwr-Allocated Oper
Fan Type Watts A @42V State
1 WS-C6509-E-FAN 150.36 3.58 OK
Pwr-Requested Pwr-Allocated Admin Oper
Slot Card-Type Watts A @42V Watts A @42V State State
1 WS-X6748-SFP 254.94 6.07 - - on off (not supported)
2 WS-X6748-SFP 254.94 6.07 254.94 6.07 on on
5 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
6 WS-SUP720-3B 282.24 6.72 282.24 6.72 on on
8 WS-X6704-10GE 295.26 7.03 295.26 7.03 on on
9 WS-X6748-GE-TX 325.50 7.75 325.50 7.75 on on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit = 10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used = 1590.54 Watts (37.87 Amps @ 42V)
system auxiliary power used = 0 Watt
But,When We show module,it is OK:
NJ-GL-ASW-2.YPT.C6509# show module
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL1424KCY0
2 48 CEF720 48 port 1000mb SFP WS-X6748-SFP SAL16148SUZ
5 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAL100194GS
6 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL14049C6D
8 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL1629HCC7
9 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1532LR5U
Mod MAC addresses Hw Fw Sw Status
1 5475.d031.ab14 to 5475.d031.ab43 2.3 12.2(18r)S1 12.2(33)SXI3 Ok
2 f0f7.55a1.e83c to f0f7.55a1.e86b 2.4 12.2(18r)S1 12.2(33)SXI3 Ok
5 0014.a97e.4e9c to 0014.a97e.4e9f 4.7 8.5(4) 12.2(33)SXI3 Ok
6 001f.6c77.b080 to 001f.6c77.b083 5.9 8.5(3) 12.2(33)SXI3 Ok
8 a493.4c1f.d6d0 to a493.4c1f.d6d3 3.2 12.2(14r)S5 12.2(33)SXI3 Ok
9 30e4.dbf0.7d30 to 30e4.dbf0.7d5f 4.1 12.2(18r)S1 12.2(33)SXI3 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL1426LS8P 4.1 Ok
2 Centralized Forwarding Card WS-F6700-CFC SAL16127Y8W 4.1 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL10019BSE 2.7 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL10019AB9 2.11 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAL140399Y5 2.6 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL14049B7Y 4.0 Ok
8 Centralized Forwarding Card WS-F6700-CFC SAL1628GJ86 4.1 Ok
9 Centralized Forwarding Card WS-F6700-CFC SAL1532M0YP 4.1 Ok
Mod Online Diag Status
1 Pass
2 Pass
5 Pass
6 Pass
8 Pass
9 Pass
What should we do?
Is the module working fine? If yes, than it could be a cosmetic bug.
BTW, the version of IOS you are running (12.2(33)SXI3) is at least 7 years old.
First,Thank you!
Yes,the module working fine!
show ver:
NJ-GL-ASW-2.YPT.C6509#show ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(33)SXI3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 27-Oct-09 11:12 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
NJ-GL-ASW-2.YPT.C6509 uptime is 3 years, 17 weeks, 1 day, 23 hours, 33 minutes
Uptime for this control processor is 3 years, 17 weeks, 1 day, 16 hours, 43 minutes
Time since NJ-GL-ASW-2.YPT.C6509 switched to active is 1 year, 14 weeks, 8 hours, 27 minutes
System returned to ROM by Stateful Switchover at 08:40:41 UTC Thu Dec 15 2011 (SP by reload)
System restarted at 17:01:32 RPC Thu Dec 15 2011
System image file is "sup-bootdisk:s72033-adventerprisek9_wan-mz.122-33.SXI3.bin"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.5) with 458720K/65536K bytes of memory.
Processor board ID SMC1519003R
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
58 Virtual Ethernet interfaces
148 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Can you tell us, the Bug situation?
Thank you !
Not sure if there is documented bug. The best way to find out is to open a ticket with TAC and have them help you in figuring it out. They probably recommend an IOS upgrade.
