12-23-2021 07:18 PM
I need this package: c7600-fpd-pkg.122-33.SRE4.pkg to upgrade card 2/0 8xFE TX SPA
because were disabled.
Error:c7600
Dec 23 21:00:27: %FPD_MGMT-3-PKG_FILE_SEARCH_FAILED: FPD image package (c7600-fpd-pkg.122-33.SRE4.pkg) cannot be found in system's flash card or disk to do FPD upgrade.
Dec 23 21:00:27: %FPD_MGMT-3-CARD_DISABLED: SPA-8X1FE-TX-V2 card in subslot 2/0 is being disabled because of an incompatible FPD image version. Note that the c7600-fpd-pkg.122-33.SRE4.pkg package will be required if you want to perform the upgrade operation.
Dec 23 21:00:27: %SPA_OIR-6-OFFLINECARD: SPA (SPA-8X1FE-TX-V2) offline in subslot 2/0
SLOT 2: Dec 23 21:00:27: %SIPSPA-4-SPABUS2: Bay 0 RD failed. sz=3 rd_par=0 noresp=1 absent=0 err_l=0 addr=0x0 data=0xFFFFFFFF parity=0x1 deadman=100
Solved! Go to Solution.
12-23-2021 08:08 PM
File can be downloaded from HERE.
12-23-2021 08:08 PM
