Join Customer Connection to register!
354
Steven Tolzmann
Beginner
C881 - WAN Port hangs after modem reboot
Hello everyone,
I have a Cisco 881 router that I am configuring for my company...
I am running into a problem while testing the device. If I unplug the modem that FastEthernet4 is plugged into (WAN Port), the FA4 light will go out, but then come back on when the Modem is rebooted... However no traffic is able to pass the port. I have the port assigned a static IP Address. I have to shutdown and no shutdown the port, or reboot the router. Our ASAs and Cisco 871s do NOT do this.... Can anyone help???
Many thanks!
1 REPLY 1
Steven Tolzmann
Beginner
Here is config:
! Last configuration change at 18:34:11 UTC Wed Jul 13 2011
version 15.0
no service pad
hostname Router
boot-start-marker
boot-end-marker
enable secret *
no aaa new-model
memory-size iomem 10
ip source-route
ip dhcp database flash:dhcp-bindings
ip dhcp excluded-address 192.168.200.1 192.168.200.100
ip dhcp pool LAN
   network 192.168.200.0 255.255.255.0
   default-router 192.168.200.1
   domain-name *
   dns-server 192.168.9.2
   option 66 ip 192.168.9.50
ip cef
no ipv6 cef
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key * address *
crypto isakmp keepalive 10
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map cmap1 5 ipsec-isakmp
set peer *
set transform-set ESP-3DES-SHA
match address to_hq
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address * 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
no keepalive
crypto map cmap1
interface Vlan1
ip address 192.168.200.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list NAT interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 *
ip access-list extended NAT
deny   ip 192.168.200.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 192.168.200.0 0.0.0.255 any
ip access-list extended to_hq
permit ip 192.168.200.0 0.0.0.255 192.168.0.0 0.0.255.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
scheduler max-task-time 5000
end
