C9200-24P switch and AP2802E (Power Consumption)
eeebbunee
Level 3
Level 3
Hello Professionals,
I used to have C2960X series PoE switch, and it connected to Aironet 2802E AP with Full power provided.
However, after I replace siwtch to C9200-24P (PoE), switch does NOT provide full power to my 2802E AP.
Even I setup manually to provide the maximum power (30W), my AP still shows that it has medium power (15.4W) from the controller.
So, I put power injector between switch port and AP, nothing is changed.
Do you think that is switch issue?
Thank you.
7 Replies 7
Leo Laohoo
Post the complete output to the following 9200 commands:
  1. sh version
  2. sh power inline
Hello Leo,
1. sh ver
Technology Package License Information:
Technology-package Technology-package
Current Type Next reboot
network-essentials Smart License network-essentials
dna-essentials Subscription Smart License dna-essentials
Smart Licensing Status: UNREGISTERED/EVAL EXPIRED
cisco C9200-24P (ARM64) processor with 649160K/3071K bytes of memory.
Processor board ID FOC-
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
4060240K bytes of physical memory.
819200K bytes of Crash Files at crashinfo:.
1941504K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 74:
Motherboard Assembly Number : 73-
Motherboard Serial Number : FOC-
Model Revision Number : H0
Motherboard Revision Number : D0
Model Number : C9200-24P
System Serial Number : FOC-
Switch Ports Model SW Version SW Image Mode
* 1 32 C9200-24P 16.12.3a CAT9K_LITE_IOSXE INSTALL
Configuration register is 0x102
2. sh power inline
MCA-Sec-C1#sh power inline (port#21, 22 are conntected to AP2802E).
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 370.0 86.0 284.0
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/1 static off 26.0 n/a n/a 26.0
Gi1/0/2 auto off 0.0 n/a n/a 30.0
Gi1/0/3 auto off 0.0 n/a n/a 30.0
Gi1/0/4 auto off 0.0 n/a n/a 30.0
Gi1/0/5 auto off 0.0 n/a n/a 30.0
Gi1/0/6 auto off 0.0 n/a n/a 30.0
Gi1/0/7 auto off 0.0 n/a n/a 30.0
Gi1/0/8 auto off 0.0 n/a n/a 30.0
Gi1/0/9 auto off 0.0 n/a n/a 30.0
Gi1/0/10 auto off 0.0 n/a n/a 30.0
Gi1/0/11 auto off 0.0 n/a n/a 30.0
Gi1/0/12 auto off 0.0 n/a n/a 30.0
Gi1/0/13 auto off 0.0 n/a n/a 30.0
Gi1/0/14 auto off 0.0 n/a n/a 30.0
Gi1/0/15 auto off 0.0 n/a n/a 30.0
Gi1/0/16 auto off 0.0 n/a n/a 30.0
Gi1/0/17 auto off 0.0 n/a n/a 30.0
Gi1/0/18 auto off 0.0 n/a n/a 30.0
Gi1/0/19 auto off 0.0 n/a n/a 30.0
Gi1/0/20 auto off 0.0 n/a n/a 30.0
Gi1/0/21 static off 30.0 n/a n/a 30.0
Gi1/0/22 static off 30.0 n/a n/a 30.0
Gi1/0/23 auto off 0.0 n/a n/a 30.0
Gi1/0/24 auto off 0.0 n/a n/a 30.0
Is CDP or LLDP enabled on the switch?
If the AP is connected to the switch, the model of the AP should show in the "sh power inline" output.  The output you've provided shows up as "n/a".
LLDP is enabled but CDP isn't because of bunch of duplex-mismatch logs.
When I enable CDP, I got bunch of these:
Jan 31 2023 06:06:59.482: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:07:09.506: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:07:12.509: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:07:15.512: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:02.923: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:35.675: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:36.686: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:37.689: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:47.700: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
Jan 31 2023 06:08:50.706: %CDP-4-DUPLEX_MISMATCH: duplex mismatch discovered on GigabitEthernet1/0/45 (not half duplex), with MCA_2802E_AP_13 GigabitEthernet0 (half duplex).
I had to disable the cdp.. and for the test, I enabled CDP for a while, but even though I enable the CDP, switch power provides 'medium power(15.4W)'... I'm about to frustrating myself...
Jaderson Pessoa
hello,
please, share below information:
show interface gi 1/0/21 / show run interface gi 1/0/21
show nterface gi 1/0/22 / show run interface gi 1/0/21
try to setup speed of interface for 100... times ago i had the same problem, but it was a cable issue and i had to put interface as 100mbps.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Hello, Here is the information.
For now, I moved AP connection to other switch, cause AP doesn't work due to medium power.
sh int gi1/0/21, 22
GigabitEthernet1/0/21 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 74ad.98fe.8d95 (bia 74ad.98fe.8d95)
Description: MCA_2802E_AP_13
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, media type is 10/100/1000BaseTX
input flow-control is on, output flow-control is unsupported
Last input 18:06:21, output 18:06:21, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7380185 packets input, 1571045812 bytes, 0 no buffer
Received 4419868 broadcasts (4417807 multicasts)
0 watchdog, 4417807 multicast, 0 pause input
31170059 packets output, 2924063985 bytes, 0 underruns
Output 10863550 broadcasts (0 multicasts)
0 output errors, 0 collisions, 10 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
MCA-Sec-C1#sh int gi1/0/22
GigabitEthernet1/0/22 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 74ad.98fe.8d96 (bia 74ad.98fe.8d96)
Description: MCA_2802E_AP_14
Last input 18:05:52, output 18:05:51, output hang never
7376333 packets input, 1570531670 bytes, 0 no buffer
Received 4419627 broadcasts (4417617 multicasts)
0 watchdog, 4417617 multicast, 0 pause input
31167411 packets output, 2923680169 bytes, 0 underruns
Output 10863845 broadcasts (0 multicasts)
0 output errors, 0 collisions, 9 interface resets
and the sh run int gi1/0/21-22 :
interface GigabitEthernet1/0/21
description MCA_2802E_AP_13
switchport access vlan 15
switchport mode access
power inline port priority high
power inline static
duplex full
no cdp enable
end
MCA-Sec-C1#sh run int gi1/0/22
Building configuration...
Current configuration : 228 bytes
interface GigabitEthernet1/0/22
description MCA_2802E_AP_14
power inline port 2x-mode
power inline static
duplex full
no cdp enable
end
For your information, I put power inline 2x-mode and priority high to provide maximum power. (Not 15.4W).
I did whatever I can..
Thank you so much Mr.Pessoa.
What firmware is the 2800 on?
Early firmware has a bug where the AP do not know how to negotiate speed and duplex due to a bug.
