01-07-2022 05:41 AM
we have core switches with PID : C9500-24Y4C and the current version is 17.03.04 , PID: C9200-24P with module C9200-NM-4X and the current version of C9200 is 17.03.04b
once I connect the uplink between the C9500 & C9200 using the 10G-SR the C9200 is not reachabe and not appearing at show cdp neighbor, the link is up & working fine on 1G
Note : I tested with another switches & fiber and it's same status
01-07-2022 05:46 AM
Use a different firmware on the 9200/9200L.
01-07-2022 06:08 AM
try nonegotiation command on the interface config.
also post show interface x/x show run interface x/x from both the ends.
01-11-2022 11:40 AM
I had exactly the same issue with the same products.
Had to downgrade to 16.12 to fix this.
Seems to be a compatibility issue between NM-4X & IOS-XE 17.4.3 on the 9200 platform.
01-11-2022 12:11 PM
Open TAC case to investigate for you, since i do not have that version to test for you, 17.3.3 works as expected.
