C9200L-24P-4G upgrade via cisco prime 3.7.0 with device pack 2
Hi, I try to upgrade C9200L-24P-4G  version16.12.4 in Cisco Prime infrastructure 3.7.
here is log from CISCO sw
[1]: Expanding file
... expanding file completed
[1]: Verifying parameters
[1]: Expanding superpackage flash:cat9k_lite_iosxe.17.03.04b.SPA.bin
[1]: ... parameters verified
[1]: Validating package type
[1]: ... package type validated
[1]: Copying package files
[1]: cat9k_lite-rpbase.17.03.04b.SPA.pkg
[1]: cat9k_lite-rpboot.17.03.04b.SPA.pkg
[1]: cat9k_lite-srdriver.17.03.04b.SPA.pkg
[1]: cat9k_lite-webui.17.03.04b.SPA.pkg
[1]: WARNING: A different version of provisioning file packages.conf already exists in flash:
[1]: WARNING: The provisioning file from the expanded bundle will be saved as
[1]: WARNING: flash:cat9k_lite_iosxe.17.03.04b.SPA.conf
[1]: ... package files copied
[1]: SUCCESS: Finished expanding all-in-one software package.
[1]: Finished expanding all-in-one software package in switch 1
Image file expanded
SUCCESS: install_add Tue Nov 9 09:39:33 CET 2021
[5|install_add_activate_commit(CONSOLE, )]: Activating PACKAGE
[5|install_add_activate_commit(INFO, )]: global_trans_lock: /bootflash/.installer/install_global_trans_lock
[5|install_add_activate_commit(INFO, )]: tmp_global_trans_lock: /tmp/tmp_install_global_trans_lock
[5|install_add_activate_commit(INFO, )]: tmp lock does not exist: /tmp/tmp_install_global_trans_lock
[5|install_add_activate_commit(INFO, require user prompt)]: install_cli
[5|install_add_activate_commit( FATAL)]: Cannot proceed activate because of user input
and here is log from Prime:
Failed to update the boot configuration in the device. Details:-Software install command execution Failed:Error occured while executing the command install add file flash:cat9k_lite_iosxe.17.03.04b.SPA.bin activate commit.Command Output : FAILED: install_add_activate_commit /flash/cat9k_lite-webui.17.03.04b.SPA.pkg /flash/cat9k_lite-srdriver.17.03.04b.SPA.pkg /flash/cat9k_lite-rpboot.17.03.04b.SPA.pkg /flash/cat9k_lite-rpbase.17.03.04b.SPA.pkg: Cannot proceed activate because of user inputNov 9 09:42:57.910 %INSTALL-3-OPERATION_ERROR_MESSAGE: R0/0: install_engine: Failed to install_add_activate_commit package flash:cat9k_lite_iosxe.17.03.04b.SPA.bin, Error: install_add_activate_commit /flash/cat9k_lite-webui.17.03.04b.SPA.pkg /flash/cat9k_lite-srdriver.17.03.04b.SPA.pkg /flash/cat9k_lite-rpboot.17.03.04b.SPA.pkg /flash/cat9k_lite-rpbase.17.03.04b.SPA.pkg: Cannot proceed activate because of user input
marce1000
 - In Prime , check if there is a flag to allow or 'set' reload (reboot) for the intended upgrade , make sure this is allowed - then try again.
 M.
8 Replies 8
balaji.bandi
I never tried it, Never myself got success before any upgrades using prime. (may be people had success stories)
have you checked compatable matrix has upgrade support from Pi 3.7
https://www.cisco.com/c/en/us/support/cloud-systems-management/prime-infrastructure/products-device-support-tables-list.html
i would advise to do it on device as per the release notes
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9200/software/release/17-3/release_notes/ol-17-3-9200.html
BB
in Prime Infrastructure 3.7 Device Pack 2 is C9200L-24P-4G recorded
PI was never programmed to react when this kind of error message appears.
I have seen this exact error message in router and switches that runs on IOS-XE.  Here is the fix:
  1. rename flash:packages.conf flash:packages.conf.00-
  2. rename flash:cat9k_lite_iosxe.17.03.04b.SPA.conf flash:packages.conf
  3. Make sure the boot variable string points to "packages.conf".
  4. Reboot the switch.
I saw that before, but i but I want to do it in a generic, "one-click way"
I don't want to overwrite files on every switch :-/... i have about 100switches
marce1000
 M.
thank you very much.
option "Instert boot command" was the solution
 only this options i have
I have the PI 3.9.1 and i had the same problem
I try to upgrade but first time fail in the activation. The second time previously i executed the command "install remove inactive", next i tried to distribuited and activate using the PI and the upgrade was succesfully.
The SW was 9300-40
New Version: Bengaluru 17.6.3
