C9300-NM-4G for Catalyst 9300 - Routed ports/Dot1q
YHam
Hello all,
I'm trying to find out if each individual port on C9300-NM-4G module is a routed port and can have sub-interface with dot1q (Vlan tag) enabled?
I have been searching online but didn't find any document that answer the questions. I assume they are uplink ports so should support layer-3 and sub-interfaces etc but want to confirm so don't get surprised later.
Reza Sharifi
The ports can be used as routed ports but sub-interfaces are not supported. You can use vlans with SVIs instead.
Hi Reza,
Thank you for the reply. Just to clarify, can each port be part of different vlan?
Can you share the official source of this information?
Thanks again
regards
Yes, each port can be in a different vlan. Functionality wise, there is no different between these ports and other port on the switch except in most cases these ports are used for uplinks.
