C9300: Routing ACL's on Tunnel interfaces don't work for outbound
Nadav
Level 7
Level 7
Hi everyone,
I'm testing Catalyst 9300's with 16.12.x softwar.e
I have a GRE tunnel between two stacks of 9300's. I'm trying to apply an ACL on the tunnel interfaces which connect them (extended with object groups, but also tried a simple one without object groups).
For the inbound on the Tunnel interface, they work as expected.
For outbound, it doesn't block anything at all. Even if I were to put a "permit ip any any log" or "deny ip any any log" I wouldn't see anything blocked or in the log.
Is this a known limitation of the 9300 platform? For ISR's and ASR's, outbound on Tunnels works just fine. But I realize that switches may have certain limitations, even though I couldn't find this one in the documentation.
Thanks!
Muhammad Awais Khan
You said you have GRE between two devices and switches are between GRR devices ?
Can you describe more at what type of interface you apply the tunnel ? Layer 3 or later 2 or it is SVI ?
The GRE is configured on the two 9300 stacks, as seen here:
The filter is configured on the GRE tunnel interface of the 9300. The tunnel source is an SVI, and the destination is the SVI of the opposite stack.
