12-01-2020 04:03 PM
We have an implementation project coming up around the beginning/middle of January 2021 using C9300/C9500 switches into 4-post racks. Unfortunately, the lead times on the 4-post mounting kits are out to the end of March right now. I was wondering if anyone thinks that the mounting holes on the C9xxx chassis would line up with the 4-post mounting kits for maybe the C3650 or C3850 switches? Or maybe a 4-port kit from another 1RU switch?
12-01-2020 06:11 PM
If i understand correctly you like to use other device kit ears and rack kit - i do not believe hey work with Cat 9500 or Cat 9300
May be 3850 may match for Cat 9300 (not sure ) - but Cat 9500 is totally different. you need to order the correct part.
anyway, they come with a product?
12-03-2020 06:19 AM
Only the 2-post (front) rack mount ears come with the product. I need the extensions for mounting into a four-post rack.
12-01-2020 06:19 PM
Hard to tell but since the part numbers are not the same, I would say you can't use a 3850 or 3650 rack mount kit on a 9500.
12-03-2020 06:53 AM
Poking around a bit on the web, it seems like the 3650 4 post kit works for the 9300, but I haven't found a substitute for the 9500s yet.
12-03-2020 07:28 AM
The other alternative would be to get a couple of shelves to hold the switches for a couple of months until the brackets arrive.
see link:
https://www.rackmountsolutions.net/shelves-drawers/
