04-12-2011 01:35 AM - edited 03-06-2019 04:33 PM
Hi ,
I need to order a cable forHWIC-1T , which cable should i go for
1) CAB-V35FC V.35 Cable, DCE, Female, 10 Feet
2) CAB-V35MT V.35 Cable, DTE, Male, 10 Feet
3) CAB-SS-V35FC V.35 Cable, DCE Female to Smart Serial, 10 Feet
4) CAB-SS-V35MT V.35 Cable, DTE Male to Smart Serial, 10 Feet
regards
Neo
04-12-2011 01:51 AM
Hi ,
I can see in this URL table 4, that i have to use Smart Serial cable but which one shall i use Male or Female ?
regards
Neo
04-12-2011 02:09 AM
Neo,
The HWIC-1T, HWIC-2T, and HWIC-2A/S use the same Cisco Smart Serial connectors and cabling that were used on the WIC-2T and WIC-2A/S. The HWIC-1DSU-T1 will use a RJ-48 T1 cable.
Please rate the all helpfull posts.
Naidu.
04-12-2011 02:14 AM
Naidu,
I have read in that URL from which you have copy pasted to your answer. i need to know whether shall i order a MALE or FEMALE cable ?
regards
Neo
04-12-2011 02:41 AM
Neo,
I think the male and female are different in pins like Male DB-25, check the connection type at your round end so that you can order based on the type and number of pins.
Naidu.
