01-11-2024 12:01 PM
I doing a cables-lenght test in meraki. Cabels from switch to hosts are 43- 50 long, but in Meraki i see 90-100 meters. Anybody know why? How is this length calculated than it is 2 x longer?
01-11-2024 12:54 PM
The cable length is determined using TDR (Time Domain Reflectometry):
https://en.wikipedia.org/wiki/Time-domain_reflectometer
It measures the time for a signal to be reflected due to tiny imperfections in the cable termination. The signal travells at a constant speed, so the length can be calculated.
Accuracy of Cable Test with MS - The Meraki Community
01-12-2024 10:37 AM
Reflectometer "tells" me 43 meters, but Meraki 100 meters.Could be a bug in Meraki?
01-12-2024 10:39 AM
I suggest you open a support case to confirm.
01-12-2024 02:09 AM
Hi @Sewanna , I would personally get an external company in to check those cable runs. Sounds like they’ve been incorrectly terminated.
01-12-2024 10:38 AM
External companys are responsibility for that.
01-12-2024 11:06 AM
Hi @Sewanna and what are their testers showing? Have they stuck a Fluke at both ends of the cable?
01-14-2024 11:11 AM
43-50 meters, and Meraki 90-100 meters
01-14-2024 11:37 AM
To be quite honest, I trust Fluke 1000 times more than the Meraki test. I see the Meraki test more as a quick fix, so I wouldn't get too attached to it.
If in doubt, I would do as I said, open a support case.
01-13-2024 11:42 AM
What switch model and what firmware are you running? There was a recent bug with MS130s reporting double the length...
