Call connects but no voice
jcmartin
Wireless Phone --> 881W router --> VPN --> ASA5510 --> LAN with CCM and Voice Gateway
Phone registers to CCM
Internal calls work
External calls connect but get no voice in either direction
Any thoughts?
13 Replies 13
jcmartin
Note that IOS firewall in 881 and ASA abe both inspecting SCCP, and that phones on the LAN side of the VPN can call external numbers.
Is the phone under NAT?
Can you post the output of command "debug ip nat sip" on the 881 router?
Is the command "inspect sip" or "fixup sip" enabled on the ASA?
Can you take a wireshark trace of the same call between ASA and CCM and between phone and 881?
We can compare traces to find the issue.
Regards.
Using SCCP, not SIP, and the phone is not using NAT prior to being encrypted in the tunnel.  Inspect SCCP is enabled on both ends.
If I correctly understand, a call to another internal extension of CCM is OK.
The issue regarding calls that pass through the voice gateway.
Right?
Correct.  Calls that pass through the gateway ring, but there is no voice.
Is the voice gateway controlled via MGCP from CCM or is It connected via a SIP trunk?
The voice gateway is H.323 via Call Manager.
Can you post the output of "debug h245 asn1" command during problematic call?
Regards.
Jan  9 15:01:49.826: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : terminalCapabilitySet :
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 7 }
      multiplexCapability h2250Capability :
        maximumAudioDelayJitter 20
        receiveMultipointCapability
          multicastCapability FALSE
          multiUniCastConference FALSE
          mediaDistributionCapability
              centralizedControl FALSE
              distributedControl FALSE
              centralizedAudio FALSE
              distributedAudio FALSE
              centralizedVideo FALSE
              distributedVideo FALSE
        transmitMultipointCapability
        receiveAndTransmitMultipointCapability
        mcCapability
          centralizedConferenceMC FALSE
          decentralizedConferenceMC FALSE
        rtcpVideoControlCapability FALSE
        mediaPacketizationCapability
          h261aVideoPacketization FALSE
        logicalChannelSwitchingCapability FALSE
        t120DynamicPortCapability FALSE
      capabilityTable
          capabilityTableEntryNumber 32
          capability receiveAndTransmitDataApplicationCapability :
            application t38fax :
              t38FaxProtocol udp : NULL
              t38FaxProfile
                fillBitRemoval FALSE
                transcodingJBIG FALSE
                transcodingMMR FALSE
                version 0
                t38FaxRateManagement transferredTCF : NULL
                t38FaxUdpOptions
                  t38FaxMaxBuffer 200
                  t38FaxMaxDatagram 320
                  t38FaxUdpEC t38UDPRedundancy : NULL
            maxBitRate 144
          capabilityTableEntryNumber 39
          capability receiveAudioCapability : genericAudioCapability :
            capabilityIdentifier standard : { 1 3 6 1 4 1 30942 0 1 }
          capabilityTableEntryNumber 21
          capability receiveAudioCapability : g722-48k : 20
          capabilityTableEntryNumber 20
          capability receiveAudioCapability : g722-56k : 20
          capabilityTableEntryNumber 19
          capability receiveAudioCapability : g722-64k : 20
          capabilityTableEntryNumber 17
          capability receiveAudioCapability : nonStandard :
            nonStandardIdentifier h221NonStandard :
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '436C65617243686964'H
          capabilityTableEntryNumber 6
          capability receiveAudioCapability : g729AnnexA : 2
          capabilityTableEntryNumber 5
          capability receiveAudioCapability : g729 : 2
          capabilityTableEntryNumber 13
          capability receiveAudioCapability : g729wAnnexB : 2
          capabilityTableEntryNumber 14
          capability receiveAudioCapability : g729AnnexAwAnnexB : 2
          capabilityTableEntryNumber 15
          capability receiveAudioCapability : g7231 :
            maxAl-sduAudioFrames 1
            silenceSuppression TRUE
          capabilityTableEntryNumber 16
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373233316172'H
          capabilityTableEntryNumber 11
            silenceSuppression FALSE
          capability receiveAudioCapability : g711Ulaw64k : 20
          capabilityTableEntryNumber 4
          capability receiveAudioCapability : g711Alaw64k : 20
          capabilityTableEntryNumber 10
          capability receiveAudioCapability : g728 : 8
          capabilityTableEntryNumber 9
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723332'H
          capabilityTableEntryNumber 8
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723234'H
          capabilityTableEntryNumber 7
              t35CountryCode 181
              t35Extension 0
              manufacturerCode 18
            data '47373236723136'H
      capabilityDescriptors
          capabilityDescriptorNumber 1
          simultaneousCapabilities
              32,
              5,
              6,
              13,
              14,
              3,
              4,
              7,
              8,
              9,
              17,
              10,
              16,
              15,
              11,
              11,
              19,
              20,
              21,
              39
Jan  9 15:01:49.838: H245 MSC OUTGOING ENCODE BUFFER::= 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
Jan  9 15:01:49.838:
Jan  9 15:01:49.838: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= request : masterSlaveDetermination :
      terminalType 60
      statusDeterminationNumber 1491
Jan  9 15:01:49.838: H245 MSC OUTGOING ENCODE BUFFER::= 01003C4005D3
Jan  9 15:01:49.838:
Jan  9 15:01:49.842: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 86
Jan  9 15:01:49.842: H245 MSC INCOMING ENCODE BUFFER::= 0270010600088175000A801380003C000100000100000101000CC00100010004800000860A0000070008824301030180000121402780000285014080000385011080002B85015000800002000001010002000300002B
Jan  9 15:01:49.842:
Jan  9 15:01:49.842: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
      protocolIdentifier { 0 0 8 245 0 10 }
        maximumAudioDelayJitter 60
              centralizedVideo TRUE
        mcCapability
      capabilityTable
          capability genericControlCapability :
            capabilityIdentifier standard : { 0 0 8 323 1 3 1 }
          capability receiveAudioCapability : g722-64k : 40
          capability receiveAndTransmitUserInputCapability : dtmf : NULL
          capability receiveAndTransmitUserInputCapability : basicString : NULL
          capabilityTableEntryNumber 44
          capability receiveAndTransmitUserInputCapability : hookflash : NULL
          capabilityDescriptorNumber 0
Jan  9 15:01:49.846: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
Jan  9 15:01:49.846: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
Jan  9 15:01:49.846: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : terminalCapabilitySetAck :
      sequenceNumber 1
Jan  9 15:01:49.846: H245 MSC OUTGOING ENCODE BUFFER::= 218001
Jan  9 15:01:49.846:
Jan  9 15:01:49.850: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 3
Jan  9 15:01:49.850: H245 MSC INCOMING ENCODE BUFFER::= 218001
Jan  9 15:01:49.850:
Jan  9 15:01:49.850: H245 MSC INCOMING PDU ::=
      sequenceNumber 1
Jan  9 15:01:49.850: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
Jan  9 15:01:49.850: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
Jan  9 15:01:49.850: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 2
Jan  9 15:01:49.850: H245 MSC INCOMING ENCODE BUFFER::= 2080
Jan  9 15:01:49.850:
value MultimediaSystemControlMessage ::= response : masterSlaveDeterminationAck :
      decision master : NULL
Jan  9 15:01:49.850: H245 MSC OUTGOING PDU ::=
      decision slave : NULL
Jan  9 15:01:49.850: H245 MSC OUTGOING ENCODE BUFFER::= 20A0
Jan  9 15:01:49.850:
value MultimediaSystemControlMessage ::= request : openLogicalChannel :
      forwardLogicalChannelNumber 1
      forwardLogicalChannelParameters
        dataType audioData : g722-64k : 20
        multiplexParameters h2250LogicalChannelParameters :
          sessionID 1
          mediaControlChannel unicastAddress : iPAddress :
            network '0A000206'H
            tsapIdentifier 25163
Jan  9 15:01:49.850: H245 MSC OUTGOING ENCODE BUFFER::= 030000000CA013800B050001000A000206624B80
Jan  9 15:01:49.850:
Jan  9 15:01:49.854: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 20
Jan  9 15:01:49.854: H245 MSC INCOMING ENCODE BUFFER::= 030000000CA013800B050001000A012C140FA100
Jan  9 15:01:49.854:
Jan  9 15:01:49.854: H245 MSC INCOMING PDU ::=
          sessionID 1
            network '0A012C14'H
            tsapIdentifier 4001
Jan  9 15:01:49.854: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
Jan  9 15:01:49.854: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
Jan  9 15:01:49.854: H245 MSC OUTGOING PDU ::=
value MultimediaSystemControlMessage ::= response : openLogicalChannelAck :
      forwardMultiplexAckParameters h2250LogicalChannelAckParameters :
        mediaChannel unicastAddress : iPAddress :
          network '0A000206'H
          tsapIdentifier 25162
          network '0A000206'H
        flowControlToZero FALSE
Jan  9 15:01:49.854: H245 MSC OUTGOING ENCODE BUFFER::= 22C000000680134C000A000206624A000A000206624B03000100
Jan  9 15:01:49.854:
Jan  9 15:01:50.314: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 23
Jan  9 15:01:50.314: H245 MSC INCOMING ENCODE BUFFER::= 22C000000480101C00000A01256B5CF0000A01256B5CF1
Jan  9 15:01:50.314:
Jan  9 15:01:50.314: H245 MSC INCOMING PDU ::=
        sessionID 1
          network '0A01256B'H
          tsapIdentifier 23792
          network '0A01256B'H
          tsapIdentifier 23793
Jan  9 15:01:50.314: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
Jan  9 15:01:50.314: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
Jan  9 15:01:56.770: %ISDN-6-CONNECT: Interface Serial0/0/0:21 is now connected to 12076504585 N/A
Jan  9 15:02:22.670: %ISDN-6-DISCONNECT: Interface Serial0/0/0:21  disconnected from 12076504585 , call lasted 25 seconds
And two interesting developments.  I tried a call to another outside number and actually got two-way voice for about a second or two before it stopped.  Also, it doesn't matter which side of the VPN the phone is on.  I brought one back to the central site and am still having the same problems.  But it seems to only be with the wireless phones.
Have you allowed the RTP ports through in both directions
UDP 16384 to 32767
Alex
Regards, Alex. Please rate useful posts.
As I said, it is also happening when I bring the phone back to the central office and eliminate the VPN and firewall from the picture entirely.
jcmartin
I think I finally got it figured out.  Primarily, I think it was a phone load bug, so I upgraded the phone load and it was mostly fixed, though I did have to tweak the VPN ACL a bit, also, as once the phone load was updated, the symptoms changed slightly.  Thanks for the advice.
