I'm trying to activate call-home feature on Catalyst 4506-E switch. I have SUP7L-E. All commands releated to call-home are missing? Do I need to upgrade or what should do the trick? Version details below.
Thank you,
Petri
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.02.00.XO RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 22-Sep-11 19:53 by prod_rel_team
Image text-base: 0x100A1274, data-base: 0x13CD8B60
ROM: 15.0(1r)SG3
Jawa Revision 7, Winter Revision 0x0.0x3
WS-C4506 uptime is 50 minutes
Running default software
License Information for 'WS-X45-SUP7L-E'
License Level: lanbase Type: Permanent
Next reboot license Level: lanbase
cisco WS-C4506-E (MPC8572) processor (revision 4) with 2097152K/20480K bytes of memory.
Processor board ID SPE160400DU
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
1 Virtual Ethernet interface
148 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
