The Maximum Call Duration Timer service parameter also controls the maximum conference duration In call manager system parameters under general feature clusterwide parameters there is a "Maximum Call Duration Timer". Adjust that to the length you wish and update. Here you can limit the timing for very low. This feature is available in call manager. This is a clusterwide parameter so it will affect ALL calls in your system so be careful with that.
