07-09-2014 07:05 PM - edited 03-07-2019 08:00 PM
Dear all,
Can I terminate 40 Mbps DSL BROAD BAND connection in Cisco 800 series router?.It is not a leased line.
Which Router model is best for 40 Mbps DSL Broad band termination ?
Thanks&Regards
Ajay Jose K
Solved! Go to Solution.
07-11-2014 01:03 AM
Hi ,
Below link provides you all model in 800 series .
For your requirement below model should suffice .
Complete throughput from the router is 51 Mbps .
Sandy
07-09-2014 07:42 PM
Hi Jose ,
Below datasheet give you performance of router series . What is your user capacity connect behind this router ??.
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Sandy
07-10-2014 02:22 AM
Hi santhosh,
Thank you for your response
But that model routers not available.I have to terminate ppoe connection.
http://www.cisco.com/c/en/us/products/routers/800-series-routers/models-comparison.html
Thanks&Regards
Ajay Jose K
07-10-2014 03:01 AM
Share me Show version or Part Number for your router .
Sandy
07-10-2014 10:39 PM
Hi Sandy,
I have to purchase router. I want to configure PPOE inside that router.
It is 40 Mbps broad band connection.From ISP optical device we will get ethernet output.
We should terminate this ethernet connection our cisco device.Costomer demanding Cisco800 series router.
Ajay
07-11-2014 01:03 AM
Hi ,
Sandy
07-11-2014 12:28 PM
Dear sandy,
Thank you for your reply
Thanks®ards
Ajay
07-20-2014 01:06 AM
Dear sandy,
Cisco C891 is not available in this market.
Can I go with 881k9 model ?
is it support 40 mbps DSL connection ?
Ajay Jose K
