Can not ping..
Ahmede
Two sites are connected as LAN-to-LAN VPN (using Cisco 3005 VPN box). In site A, we can ping/Telnet/Trace all the IP's in site B, except 3 machines. These 3 machine on the same subnet, we can ping the rest of the IP's on the same subnet. These 3 machines are pingable within Site B. We have a single machine in Site A that can ping these 3 machines. When we trace to one of these 3 IP's, we go up to the router that's connected to these machines. Again no access list, security devices are blocking the traffic..Any Idea what could be the problem.. Thanks in advance..
mantha_nagendra
Hi.
The issue seems to be with the configuration at the router serial and ethernet configuration.
Also check the routing protocols and the physical connectivity.
Hope this will resolve the issue.
