Can't Access 3650 Web Panel (but works on CLI)
BashedRoot
Level 2
Level 2
Strange issue here. I have 2 x 3650 switches both running Version 3.76. Web interface shows fine, but cannot log into switch #1.
I've had no issues accessing the panels via web on both switches, saved my passwords locally in Roboform too. Suddenly, my login is not working for switch #1, but works fine on switch #2. I'm baffled.
How do I correct this?
I checked the user/pw in show run
enable secret 5 ********
enable password ********
42 Replies 42
Small correction, I use SSH2 protocol not telnet.
I also added a new username with 15 privilege in the web GUI. It got me in via SSH2 directly into enable mode. One step forward, however, still want the prior user authentication first for extra security.
Here's where I'm stuck now.
Cisco3650#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Cisco3650(config)#line vty 0 4
Cisco3650(config-line)#login local
^% Invalid input detected at '^' marker.
What are your options at 'login' ?
login ?
Try and remove the aaa model
no aaa new-model
Not working for me.
Cisco3650#conf t
Cisco3650#
Cisco3650#conf t
Cisco3650(config)#no aaa new-model
Changing configuration back to no aaa new-model is not supported.
What do you get after 'login' ?
Cisco3650(config-line)#login ?
Also, at:
just hit <enter>, this should delete the aaa model. The message is just a warning...
Yes I hit enter, tried to log in again but still goes directly to enable mode, skipping the myusername auth step prior (like I had before).
Can you post the output of that ? There should be a 'local' option...
This is the only thing I see from the moment I log in (goes directly into enabled mode) and running that command, nothing else.
Cisco3650#
Cisco3650#conf t
Cisco3650(config)#
Cisco3650(config)#end
Cisco3650#wr
Building configuration...
Compressed configuration from 24401 bytes to 9027 bytes[OK]
Cisco3650#
Here's a comparison of the 2 switches.
Switch #1 (main one trying to fix)
version 16.3
no service pad
service password-encryption
service compress-config
no service password-recovery
no platform punt-keepalive disable-kernel-core
hostname Cisco3650
vrf definition Mgmt-vrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no aaa new-model
clock timezone EST -5 0
facility-alarm critical exceed-action shutdown
switch 1 provision ws-c3650-24ts
Switch #2 (works correctly by logging into myusername first and manually having to enter "en" mode)
version 16.3
no service pad
hostname Switch2
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
no logging console
enable secret 5 xxxxxxxxxxxxxxxx
enable password TLNsxxxxxxxxxxxxxxxx
no aaa new-model
switch 2 provision ws-c3650-24ts
What does the VTY line configuration look like on both switches ?
line vt 0 4
Switch #1
control-plane
 service-policy input system-cpp-policy
line con 0
 exec-timeout 480 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 access-class Manage-SSH in
 exec-timeout 480 0
 login local
 length 0
 transport input ssh
line vty 5 15
 exec-timeout 480 0
 login local
 length 0
 transport input ssh
Switch #2
control-plane
line con 0
 exec-timeout 480 0
 login local
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 exec-timeout 480 0
 login local
 length 0
 transport input ssh
line vty 5 15
 exec-timeout 480 0
 login local
 length 0
 transport input ssh
So in addition to the enable mode password issue on switch #1
I'm still having this odd issue with switch #2 where it works fine (logs into myusername first, then into enable mode). However, it doesn't work with new enable password I set when I log in via VPN IP address which is already whitelisted in ACL and worked fine before I reset enable password. It's crazy, I log in just fine directly via SSH2 but via the VPN IP it no longer works. It works on myusername/pw but enable pw won't work. Same one works directly into switch.
ACL config is 100% identical on switches #1 and #2 as well.
I would appreciate some help here.
Everest 16.6.2 has this issue as well.
