Can't ping P2P between 2 Nexus 9k's
rkoloj
I can't ping between 2 Nexus 9k's.  Both interfaces are configured as follows:
Nexus Switch 1:
int eth1/18
 ip address 192.168.1.1/31
 no shut
Nexus Switch 2:
int eth1/18
 ip address 192.168.1.2/31
 no sh
I also tried configuring an 'ip route' on either switch to each other.  It's still saying 'no route to host'....Do I need a routing protocol put on the interface since it a 'routed' port?  Thanks for your help!
Hello!
In a way, the Nexus is telling you the truth here - 192.168.1.1/31 and 192.168.1.2/31 are in different subnets. Since you are using /31 subnets, the two IP addresses in the first subnet are 192.168.1.0 and 192.168.1.1, while the two IP addresses in the second subnet are 192.168.1.2 and 192.168.1.3. Therefore, 192.168.1.1/31 and 192.168.1.2/31 are in two different subnets.
To fix this, you have the following options:
  1. Configure Nexus Switch 1 with an IP address of 192.168.1.0/31 and Nexus Switch 2 with an IP address of 192.168.1.1/31.
  2. Configure Nexus Switch 1 with an IP address of 192.168.1.1/30 and Nexus Switch 2 with an IP address of 192.168.1.2/30.
I hope this helps - thank you!
-Christopher
balaji.bandi
i would advise to post full coinfiguration of both the sides, along with show version.
have you enabled features
post below output as suggested above :
show run
show version
show features
show interface eth1/18 (bot the sides)
BB
I cannot post full configuration, its a secure network.
Version: nxos 9.3.7
However, here is the features:
feature bgp
feature isis
feature nv overlay
feature vn-segment
The interfaces are:
Nexus Switch 1:
int eth1/18
 no shut
Nexus Switch 2:
int eth1/18
 no sh
Hello!
-Christopher
ugh duh, ok i'll try that.  thanks.
